Hydroboost conversion questions.
Old Aug 22, 2025 | 12:40 PM
BHD's Avatar
BHD
I am planning on a 2nd Gen hydroboost conversion in my '85 CrewCab.
I sourced a unit from a 2000 Dodge.
The question I have, for you guys that have done this conversion, is: Do I need to use the proportioning valve from the 2000 donor or will my current unit work? (its from a 1991.5 W250).
Thanks
Old Aug 22, 2025 | 12:52 PM
I believe if you keep with disc front and rear drum on both rigs, you can re-use the valve.
Since I believe disc braked rear axles began in the 2001 year, as I know my old '01 had a Dana 80 with discs, you should be all set.
Old Aug 22, 2025 | 04:23 PM
BHD's Avatar
BHD
Thats why I wanted a 2000 donor. It's the same hydraulics as the Road Tractor.
Old Aug 22, 2025 | 06:27 PM
u2slow's Avatar
I don't care for those later Dodge hydroboost. They stand off the firewall several extra inches, and are rotated.
I'm playing with 80's Chevy ones (mocked up, not fully installed) and if I were to start over, would be trying 92-98ish Chevy as they have a nice flat mounting plate.
Old Aug 22, 2025 | 07:05 PM
BHD's Avatar
BHD
i plan to delete that bracket on the firewall side of the Hydro in favor of a flat steel plate and make an adjustable pushrod. I also bought the adapter fittings to go from the oring tube to JIC #6. And I'll make my own pressure hoses.
Old Aug 23, 2025 | 01:38 AM
u2slow's Avatar
So far I've got mine plumbed with stock Chevy hoses.
Old Oct 20, 2025 | 02:38 PM
BHD's Avatar
BHD
I have this part of the project done with great success. I'll post the process on the RoadTractor build thread directly.
Old Dec 24, 2025 | 01:43 PM
My hydroboost adventures....
https://www.dieseltruckresource.com/...thread-323472/
12valve
35
Oct 19, 2016 02:42 AM
dgarner1988
Aug 20, 2011 11:20 AM
hoffdog
Cummins Conversions
Aug 21, 2008 09:34 PM
SilverHoss99
Mar 22, 2006 03:24 PM
