How to repair a leaking Governor Shaft and Fuel Screw
I believe Richard's teflon fix is ingenious. I think better than a new O-ring since I don't believe teflon deteriorates like an Oring. And, trapping it tightly between washer, bolt and case will probably hold more pressure than the O-ring. Just my thoughts. My Governor shaft has been leaking for a couple months now, but I haven't been able to spare the truck, and time, to fix it. Now I can. If and when another leak develops, like behind the pump, then I'll remove it and reseal everything. Thanks Richard, and Merry Christmas to all!!!!!!!!!!!!!!!!!!!
Like I said I have never had much luck with temporary patches so I tend not to do them. Every time I do I end up spending more time re doing it than if I had done it right the first time. And I hate re doing things. but that's just me.
And Merry Christmas to you too
edwinsmith (12-14-2017)
First and foremost: Sorry for your loss on both accounts.
I've done this with water valves before that would've needed replaced and it worked. I'd be worried about the teflon tape ending up in the IP and causing problems. I do have petroleum rated teflon tape. Great idea for an emergency repair!
mknittle (12-16-2017)
No Chance of teflon getting in pump!
brianshog (07-05-2021)
I finally repaired my ve's leaking governor shaft. I'd like to give a brief summary for the benefit of others who might need to use this fix. After bending the small tube out of the way, backing out the governor shaft nut till it contacted the timing case produced a gap of approximately 3/32" (a little over 1/16" on each side of the washer to place the teflon). I used a thick blue 1/2" wide teflon tape I had which is rated for gas and I don't know what all. I cut off a 3" piece, twisted it into a rope and then rolled in between my thumb and fingers. This produced a teflon string slightly less than 1/16" diameter which I could slip under the governor shaft, between the washer and IP housing. I captured the ends of the teflon string using small hemostats, pulled them around the shaft past one another, and tucked the ends in as best I could with a small dental pick. Then, using a small screwdriver and levering against the nut, I slid the washer tightly against the IP trapping the teflon. When I released the screwdriver pressure the washer stayed in place leaving an adequate gap on its front side. I did the same on the front side of the washer and tightened the nut. Voila!!!! It took over an hour before the lightbulb went on and I realized hemostats would make the job easy. Prior to that I tried needle nose pliers, screwdrivers, dental tools etc. As nativegator said above, bending the small steel tube out of the say could be a risk. I ultimately bent it completely out of the way, like the fitting moved several inches, but it bent back without damage. Drove the truck for an hour and no more governor shaft leak, but the end plug on the KSB was now leaking. Replaced its O'ring and now, for the first time in at least six months, I can park in a driveway. The KSB O'ring was not broken or obviously abraded, but was brittle. It broke when I tried to remove it. I think it was just inflexible and compressed and leaked due to increased pressure from the timing spacer (just my guess). Obviously my pump is due for a reseal. I can also see wetness at the base of the IP fuel inlet fitting, but no drips yet. Does anyone know how that fitting is sealed? I read it is a 12MMx1.5 so I assume there is an O'ring, washer or flare seal at its base. I don't wish to mess with it further till I have the fix in hand. The 14mm fuel line compression nut is seized up in it, so I haven't removed it to investigate. I've got a spare fuel tube with the 14mm nut so I can cut the existing fuel tube and remove the 17mm fitting with the 14mm in it, if necessary, but didn't want to do that till I was sure I can reseal that lower fitting. Hope this makes sense. TIA!
KSB O ring side of road teflon tape fix...
The KSB solenoid O ring usually is in pretty terrible shape, and is easily replaced. But if no replacement is available the fuel leaking comes from shrinkage due to age. It is usually in tact but very brittle. As I mentioned before, a quick fix for the side of the road is simply wrapping the old O ring with Teflon tape and reassembling until you get a new O ring. These fuel leaks are due to O ring shrinkage. As far as the wetness around your fuel line, if that's all it may be so very minor you should just leave it. I say this because you stated it was frozen or locked up. Old Mercedes diesels always seemed to have minor dampness around thier well worn injection lines, it never hurt them. As long as it's not a drip. EBay seems to be an incredible source for new lines and parts. Most dodge owners are meticulous and any dampness would bother them. Just make sure you are ready for expense and down time before you force the nut. I have good luck removing repositioning and retightening dripping leaky lines if they aren't frozen, or locked up. It doesn't sound like it will work but has worked well several times. I wish I could help more about your line. Richard
Thanks for the good advice nativegator. I still want to replace the stock fuel supply tube and fittings between the IP and fuel filter with 12mm x 1.5 to AN fittings and hose, as per a fuel line upgrade thread I recently read on this site. (I don't like that I can't readily service it now.) I am just about to order AN fittings with crush washers, but am not certain that is the correct seal. Still hoping someone knows how the stock fuel inlet fitting is sealed.
I'm not 100% sure but I think it's just flared?
I believe it's just flared, but just contact your local injection shop and you eventually will find someone who will know. These 1st gens are a favorite among diesel mechanics. Let's us know. If I remember right the fuel line is just flared out, but I could have been mistaken and ignored a crush washer stuck in there, lol. All I done is reposition the lines on Cummins by the way make sure your return line screen is clean in the banjo bolt on the pump. If it clogs up and it can you will blow your pump. Some times the rubber tip off the fuel shut off solenoid breaks off and is found here. Also replacement lines are in Ebay sometimes.
I'm not asking how the fuel line seals. I'm asking how the fitting is sealed that the fuel line nut is screwed into. The fitting is threaded into the IP and takes a 17mm wrench. The fuel line nut takes a 14mm wrench. Hope that's clear.
jmd4993
06-22-2013 07:36 AM
pro puller
12-24-2007 09:59 AM
