how much motor vibration at idle is normal ?
http://www.glacierdieselpower.com/pr...?pf_id=800-082
Glacier Diesel power has them. Called a dorman fitting.
I've had some odd vibrations at idle over the years for various different reasons. Mostly when it's really cold out.
Check the oil level. I was 3 quarts low once (
I know
) caused a real bad vibration.
I also had a heck of a time getting a smooth idle back after gelling up once at -45*F. Ended up setting the hand throttle to ~1000rpm and then cracking the injector lines for a bit to really bleed them out.
In your case I would consider installing some clea line between the Fuel filter and IP to see if there is any air comming into the system.
I know
) caused a real bad vibration.I also had a heck of a time getting a smooth idle back after gelling up once at -45*F. Ended up setting the hand throttle to ~1000rpm and then cracking the injector lines for a bit to really bleed them out.
I know
I know
Yeah, I should plumb some clear line in there to see what is up. Just ordered that dorman fitting, too, thanks again for the tip.
DUKCALN
23
Dec 17, 2008 09:21 AM
cjones42
May 7, 2007 12:09 PM
4x4not
39
Jan 29, 2007 05:54 PM
dodgedsl03
Jan 18, 2007 10:08 PM
