How many egts were lost with an intercooler install?
Old Jan 5, 2009 | 02:06 PM
1985cucv's Avatar
Guys how many egts did you lose by installing an intercooler on the non ic engines. I imagine it all depends on fuel power etc, but i just want to know a relative amount thanks guys
Old Jan 5, 2009 | 02:09 PM
I'd have to guess at least 150 or so. Just guessing to give you an idea
DEFINELY should be over 100 degrees with your setup.
Old Jan 5, 2009 | 02:18 PM
pwrtripls1's Avatar
if a good aftermarket IC can drop EGT's at WOT 150-200* then even adding a stock 1st gen IC to a non IC truck should drop 200-300* at WOT. Maybe even a little more depending on timing and power.
Old Jan 5, 2009 | 03:09 PM
apwatson50's Avatar
Well I would look at it differently than "loosing egt's".
I would look at it as, "how much usable power" do I gain?
With my stock IC I could tow and keep 15psi of manifold pressure cool and tow with that much "power". Anymore fuel than that and egt's would go too high.
Now with my PS IC, I can now tow with 20psi of manifold pressure and keep that cool while towing.
So I gained 5psi of usable "power" while towing.
Aaron
Old Jan 5, 2009 | 03:18 PM
rebal's Avatar
I installed a banks plate style inter cooler on my 90 .at the time it was installed I saw a 200+- drop but now I can still hit 1500* at wot but it takes longer to get there It is worth doing because it will allow you to use more power longer . towing seems to be where it shines
Old Jan 5, 2009 | 05:43 PM
1985cucv's Avatar
thanks guys this is a good baseline for me i will try to install the 2nd gen in my chevy hopefully all goes well
Old Jan 5, 2009 | 06:27 PM
BearKiller's Avatar
What is "plate style" ??
How does it differ from others ??
Thanks.
Old Jan 5, 2009 | 09:11 PM
rebal's Avatar
tubes are square thats all
Old Jan 5, 2009 | 09:33 PM
RumbleFish's Avatar
the PO of my truck swapped in a 2gen IC. he claimed it was worth a 300deg drop over the stock 1st gen IC.
Old Jan 6, 2009 | 12:35 AM
Crazy Matt's Avatar
Does that IC fit behind the stock grille?
Old Jan 6, 2009 | 06:55 AM
Ace's Avatar
Ace
My average EGT went down about 100 with the Powerstroke IC and stock injectors.
Old Jan 6, 2009 | 03:21 PM
Fergavs's Avatar
I dropped aprox 200-250deg on my 90 with a set of 60hp injectors and a fuel pin. Made a big difference. So much that I will be installing one on my 91.5 as well. I have a PS intercooler in the 90 and am getting the same thing for the 91.5.
Old Jan 9, 2009 | 01:13 PM
1985cucv's Avatar
CrazyMatt,
It will not fit behind the stock grill on my truck i think what i am going to do is weld some expanded mesh on my brushguard to act as a grill and of course put a chevy emblem on it
Old Jan 9, 2009 | 01:30 PM
dstad's Avatar
will a powerjoke i/c fit behind the grille on my 92???
Old Jan 9, 2009 | 02:50 PM
RumbleFish's Avatar
you might be able to trim, or 'shave' down the thickness of your stock 89/90 grille. the po did this to my crew. he had a banks ic behind the stock 83 grille.
