How hard is it to put hydraulic clutch pedals in an 80s gas cab?
Would a hydraulic clutch pedal and master cylinder bracket go right into an 80s gas cab? I know the electrical bulkhead connector needs to be moved but are there any other obstacles? Thanks
You need the bracket that the Hyd master cylinder locks into, it mounts up onto the steering column/pedal brackets, then drill the hole in the firewall and move the bulk head connector down and over a bit, and a bit smaller too.
GCSS
May 14, 2009 08:00 AM
