How fast is "H" on the speedo?
Old Sep 14, 2008 | 01:45 AM
89f150's Avatar
I had my old dodge diesel about the fast and it was on 35's no deeath wabble actally got steady lol
Old Sep 14, 2008 | 12:37 PM
unixcowboy's Avatar
Originally Posted by Kansascrewcab76
First gens don't suffer from the dreaded "death wobble"
Wanna bet ???
Old Sep 15, 2008 | 08:49 AM
willieboy's Avatar
Originally Posted by unixcowboy
Wanna bet ???
I second that. Come drive mine and tell me it does not have the death wobble.
Old Sep 15, 2008 | 09:21 AM
unixcowboy's Avatar
Mine's rock solid at 70 - 80 mph
Holds any line you set the steering wheel at.
Just don't do more than tap the brakes to release CC
The smallest pressure on the brakes to scrub speed and you'd better have a death grip on the steering wheel....
And what's maddening as he-double-L is it does the same thing to a lesser degree at lower speeds.
A complete front end rebuild - over $1800 - cured the problem
for about 1000 mi, then it started creeping back in.
MY '81 and '87 did it also, just not as bad. Course they both had a 440 transplanted into it. I suspect it has something to do with the extra weight on the front end.
That 440 weighed a few lbs more than the 318 or 360 that was in there originally.
Not as much as the Cummins in ours - that's a LOT of weight on the front end...
Old Sep 15, 2008 | 01:09 PM
schamran's Avatar
Brakes pulling
Mine does the same thing. Do you think that could be in the springs. When I mash the brakes, it seems like one side of the truck dives before the other. Just a thought?
Old Sep 15, 2008 | 01:44 PM
unixcowboy's Avatar
Well ----
I know one thing that's on my 'to do' list that might be causing it.
The PO used the emergency brake as a parking brake. So now the rears are egg shaped.
But yes, one end does dive before the other - except mine squats in the rear under hard braking, then levels out and starts the wobble. It's definitely weight transfer that's causing it. And 'one day' I'll replace the rear cylinders w/1 ton units and new drums and shoes. Then we'll see if it goes away or continues.
I don't get the wobble under severe hard braking, all 4 wheels grab super hard if I put my foot into it.
Old Sep 15, 2008 | 09:00 PM
CaptainChrysler's Avatar
Mine used to wobble pretty bad when you hit the brakes. New rotors fixed it.
Old Sep 15, 2008 | 10:36 PM
Rampage1967's Avatar
Same here new rotors, nice stopping. . . .
BTW. that little pedal next to the drivers door is a PARKING BRAKE not an emergency brake. Though if you stomp it at 70 it may cause an emergency.
Old Sep 15, 2008 | 10:47 PM
mhuppertz's Avatar
You have to have some serious front end issues to death wobble a solid axle with leaf springs...
Old Sep 15, 2008 | 10:49 PM
mhuppertz's Avatar
If I crank on the e-brake at 70, nothing noticible changes. Gotta do that rear disc conversion.
Old Sep 16, 2008 | 10:25 AM
unixcowboy's Avatar
Did you notice I said $1800 for a rebuild ?
The only thing they didn't replace was the axle and frame
Since then all I developed over the last 25K is a shimmy. Time to check the tie rod ends next time I lube them.
Old Sep 16, 2008 | 11:59 AM
mhuppertz's Avatar
Check the frame for cracks really well around the steering box. Mine was feeling a little loose, and the frame was cracked 1/3 of the way down, and the steering box mounting bracket was badly cracked also...
Old Sep 16, 2008 | 06:10 PM
DanMan's Avatar
I had mine up to about 100 for a couple miles last winter, it felt nice an steady at that speed. Didn't feel like I was going anywhere near 100. We had just spent a couple hours at the ND/Canadian border giving a trucker a little fuel and jump start. I was trying to keep up with him on the way back to the next gas station!
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
trik396
Mar 14, 2007 07:57 AM
