how do you get more oil pressure?
Old Jul 22, 2006 | 10:57 AM
Buffman88's Avatar
my oil pressure usually stays pretty low and i have a pretty bad leak. if i fix the rear main seal will that help any?
Old Jul 22, 2006 | 11:15 AM
Ace's Avatar
Ace
I doubt if your oil press is really low unless the engine is worn out. Try cleaning the sender contacts or replacing the sender. My gauge started reading correctly again after I unplugged the sender, sprayed it with WD40 and re-plugged it a few times to re-establish the electrical connection.
Old Jul 22, 2006 | 05:29 PM
flashgordon's Avatar
Ya my oil pressure was scarry at idle and when i changed the sensor the guages work properly!!!
Old Jul 22, 2006 | 09:52 PM
JD730's Avatar
The electrical sending units are known for being inaccurate. The best way to check the pressure is to do on a hot engine with a mechanical gauge to verify the pressure. 10psi is the minimum pressure at idle. I typically see 30psi at hot idle and it buries my 50psi gauge when I bring it off of idle.
Old Jul 22, 2006 | 10:28 PM
imabnormal's Avatar
From: Michigan (see aforementioned rusted-out rockers)
the rear main seal is not pressurized and therefore wouldn't change the pressure either way. if it's a 2-piece seal those are fairly easy to change, but the 1-piece one requires removing the trans. i don't know which one of these the cummins is, but i'm sure that many others do.
personally, i don't mess with rear mains unless they are leaking VERY bad, or i've already got the trans out or the pan off, etc.
Old Jul 22, 2006 | 11:37 PM
JD730's Avatar
The rear mains seals are 1 piece and the only time you should fool with them is when its leaking or you have a transmission out. This will not help a low oil pressure problem if one really exists. Where is it leaking? Between the trans and the engine?
Old Jul 23, 2006 | 12:39 PM
jeepsuck's Avatar
doesnt the main seals leaking generally indicate that your main bearings are worn, thus causing play in the crankshaft which in turn causes the main seals to leak?
Old Jul 23, 2006 | 02:26 PM
shift220's Avatar
Not necessarily, seals will eventually wear out from friction or foreign material on their own.
Old Jul 23, 2006 | 02:46 PM
And some time that foreign material will put grove in the crank causing the new one to leak allso.....hypotheticially
speeking!
are you shore that its not leaking from the valve cover and down the back side of the block!
Old Jul 23, 2006 | 10:36 PM
bmoeller's Avatar
Or, when they are dried out and hard from not using the truck enough.
Mine was seeping a little when the trans was replaced. I brought a new seal along just in case and they put it in for me.
kyle_truck_pull
Oct 29, 2008 02:35 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
Commatoze
Nov 20, 2003 06:06 PM
