how do i change headlight switch
Old Aug 11, 2009 | 09:33 PM
nemo451's Avatar
headlights are out. its definitely the switch. took off the dash and the plate behind it and also removed the nut/bolt thing that looks like it takes a special wrench with some needle nose vice grips but the **** and triangular shaft still wont come out. whathefuk?
Old Aug 11, 2009 | 10:00 PM
440_D50's Avatar
there is a little button style thing on the main part of the switch behind the dash. You have to reach back there and push in the little button. It can be a pain. And then you just pull the **** out of the front.
Old Aug 12, 2009 | 12:03 AM
nemo451's Avatar
yep that did it. I wouldn't have figured that one out in a million years. thanks for the quick reply.
Old Sep 7, 2009 | 12:53 AM
Power Ram 250 C's Avatar
Good thing I found this post. My headlights just went out last night so out came the old, a little burnt, switch and in with the new lifetime warranty switch. The connector had been a little hot at one point of time but still usable. So far everything seems fine but I rotated the potentiometer (****) to kick the inside cab light on and it blinked once then must have burned out. I'm going to check tomorrow to find out what really happened. Hope I don't have more problems than I thought I did.
Old Sep 7, 2009 | 04:58 AM
Jim Lane's Avatar
Now is the time to install a pair of headlight relays and take about 99% of the load off the switch contacts; the switch will last forever and as an added bonus the headlights will be up to twice as bright if you also install Silver Stars.
This is about the best lighting modification you can do to your truck.
https://www.dieseltruckresource.com/....html?t=176263
Jim
Old Sep 7, 2009 | 10:30 AM
cougar's Avatar
While you have you head up your dashboard. Look at the wire bundle were it goes past the parking brake frame. On my 91 it rubbed through the insulation and shorted out the running lights.
mtdoragary
Nov 7, 2013 08:31 AM
jesse123
Jul 8, 2012 09:04 PM
Barryn
Jul 14, 2008 09:30 AM
jlipskoc
Oct 24, 2005 01:16 PM
2nGlenn
Mar 11, 2003 01:51 PM
