How di I get the front spring eye bushings out??
Old Nov 12, 2006 | 04:08 PM
Rampage1967's Avatar
Took truck apart to fix the crack in the steering box bracket.
Inspected the frame, no cracks found.
Cleaned & inspected box bracket, no cracks found.
Drag link ends found to be tight.
Adjusted the box.
What a way to change yer power steering fluid . . . .
Old Nov 12, 2006 | 08:26 PM
Finally got it back together.
Drives straight, steering is tighter.
Has what feels like a radial tire belt shake right around 45 mph.
Steering shakes a little, feels like truck shakes side to side around 45 mph.
Does that sound like a tire shake to you guys??
Old Nov 12, 2006 | 11:20 PM
flashgordon's Avatar
Jack you tires up and spin then! If you have a belt separating you will see the tread move side to side, quit noticeably in one spot.
and yes that could cause, that what your filling!
Old Nov 13, 2006 | 02:54 PM
OK, tires look good, but I switched them front to rear anyway.
Left front was slighty out of round.
The truck drives smoother, but, on the test drive I got two very violent death wobbles.
Tie rod ends are tight.
New spring eye bushings.
Drag link, steering box & box mounts are tight.
Steering U Joint is tight.
There are no frame cracks.
Leaf spring bolts are all tight.
I guess I better dig into the wheel bearings & such deeper.
I've tried to shake the tires & couldn't detect any looseness.
Is there a special method to checking this??
Old Nov 13, 2006 | 03:58 PM
DISLSMOKE's Avatar
From what i've been told by my inspection guy, ball joint or king pin check is move the tire up and down, with it jacked up of coarse. If you feel play its your joints or king pins. Shaking the tire side ot side is how to check for tie rod ends. Check tie rod ends with a pair of channel lock plires and squeeze the joint and piece its connected to, if this sqeezes together, bad tie rod. I think this is right. Right? Chime in if i'm wrong.
Old Nov 13, 2006 | 11:03 PM
BearKiller's Avatar
A friend has a 91.5 that he spent a fortune on, trying to get rid of a front-end wobble.
Another friend talked him into adding a steering stabilizer/shock-absorber.
It fixed his truck.
Also, check your tire air-pressure.
Low pressure can do all sorts of weird stuff.
Old Nov 13, 2006 | 11:13 PM
rebal's Avatar
I drive an old large flat blade screw driver into the curl of the spring , it will open up the hole and then it takes very little effort to drive the old bushings out hope that helps
Old Nov 14, 2006 | 07:09 AM
It has a fairly new Rancho steering stabilizer on it already.
Old Nov 14, 2006 | 10:06 PM
BearKiller's Avatar
That is some good advice that I wish I had read many years ago.
Thanks.
Old Nov 15, 2006 | 05:22 AM
farmer0_1's Avatar
you may need to buy a shim to take some of the caster out of the front end. it goes between the spring and the axle housing and resembles a small wedge of cheese. had on old cj5 that would go off on the shimmmy shake and it cured it. seems like 3 degrees or so was the least i could change it. i would only do this as a last resort.
Old Nov 15, 2006 | 08:29 AM
JimmieD's Avatar
There's a TSB repair for Ram wheels. Mopar has some special lugnuts that are used to properly center the wheels on the hubs. The symptoms of problems are a shaking and vibration from front end similar to tires out of balance. The specal lugnuts P/N 01273556 with much wider flange area are installed into two opposing lug holes on wheel and all other lugnuts are then loosened. The special lugnuts are then torqued to spec to center wheel and the stock lugnuts are then tightened, and alignment lugs are removed and replace with stock lugs. One set of 2 lugs does any 8 lug wheel. Check TSB's for more info...
bgilbert
Oct 15, 2014 06:24 PM
Montana2x2
Jan 24, 2009 06:52 PM
RonA
Jul 17, 2008 01:50 AM
barryp
Oct 26, 2007 03:51 PM
CaptainChrysler
Oct 22, 2007 12:29 AM
