-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   How to add 2nd Gen / 3rd Gen Towing mirrors to a 1st Gen CTD (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/how-add-2nd-gen-3rd-gen-towing-mirrors-1st-gen-ctd-151056/)
BRUISER May 14, 2007 10:13 PM
This is a how to write up from my reference post:
https://www.dieseltruckresource.com/...d.php?t=150798
First I took the new mirrors out of the box and used some cardboard to make a template, which I could then transfer to Metal later.
http://www.impaks.com/images/ken/000_0536.jpg
The mirrors also came with a metal reinforcement plate so I used that to help locate the holes in my template.
http://www.impaks.com/images/ken/000_0533.jpg
http://www.impaks.com/images/ken/000_0534.jpg
Next it was time to start taking the old stuff off and get started.
So I first took out the small wing window, it is held on with 2 screws
http://www.impaks.com/images/ken/000_0528.jpg
I then took the old Mirror off.. There is a screw on the bottom of the chrome plate
http://www.impaks.com/images/ken/000_0529.jpg
Once you get the plate off you can then use a 10mm socket to get the mirror off.
http://www.impaks.com/images/ken/000_0530.jpg
http://www.impaks.com/images/ken/000_0531.jpg
http://www.impaks.com/images/ken/000_0532.jpg
BRUISER May 14, 2007 10:14 PM
Now back to making the steel plate.
I used the cardboard and transferred the design onto some 1/8” steel plate
http://www.impaks.com/images/ken/000_0535.jpg
the problem that I found was I made the 1st steel plate is was a little to small so I had to cut another piece of steel and remake the steel template
http://www.impaks.com/images/ken/000_0537.jpg
When I held the steel plate up to the window area I found that it was a little curved and so was the mirror plastic, so I used some Steel hammers to bend the steel top the correct shape..
Yes it is nice to have good tools :)
http://www.impaks.com/images/ken/000_0538.jpg
BRUISER May 14, 2007 10:16 PM
Once I had the plate shaped I took a air grinder and took the paint off the door so I could weld to clean steel..
http://www.impaks.com/images/ken/000_0539.jpg
Oh and good welding clothes help 
http://www.impaks.com/images/ken/000_0540.jpg
After everything was fitting correct I held the plate in place and welded it to the door..
http://www.impaks.com/images/ken/000_0541.jpg
The last part is to take the old mirror mounts off, and weld the holes up
http://www.impaks.com/images/ken/000_0542.jpg
After everything was welded up I took some Bondo and put it on the edge where the weld is, that is the only part I still have to go back and sand down..
I will get all finished pics later this week or this weekend.
Here is one of the drivers side
http://www.impaks.com/images/ken/000_0509.jpg
Hope this helps others that may be considering taking the plung to get better mirrors for towing.
BRUISER May 29, 2007 08:40 AM
Well the Mirrors worked great..
I could see the entire road and everything I was pulling..
One of the best mods I have done for towing..
click pic to see larger version
http://thumb0.webshots.net/t/53/753/...0yBiazW_th.jpg
whereswaldo250 May 29, 2007 10:02 AM
Those look sooo sweet, makes me want to do that. It does look a little intimidating. Great job Bruiser[coffee]
BRUISER May 31, 2007 10:51 AM
Thanks..
I will state that once you go this direction it will be a pain to go back.. :)
I will try to get some better full front shot this week
BRUISER Nov 5, 2008 03:21 PM
Well I know a lot of folks will hate me for doing this next mod.. but for me Good mirrors and visibilty when towing is worth it.
so yes I welded on my new style dodge mirrors.
Here is my old 1st Gen with the mirrors on it.. you can see they tilt up some..
so this time I took more time and made a new mount so they sit level, plus we braced then with some bends in steel so they woul dnot shack when driving down highway.. and so far at 70mph no shaking :)
ok on to the pics:
they are only primer for now but will be painted to match rest of truck once i paint the rest of truck..
Passenger side
http://www.impaks.com/images/ken/dodge/DSCN5172.JPG
http://www.impaks.com/images/ken/dodge/DSCN5176.JPG
Drivers Side
http://www.impaks.com/images/ken/dodge/DSCN5174.JPG
http://www.impaks.com/images/ken/dodge/DSCN5175.JPG
BRUISER Nov 5, 2008 03:22 PM
yes windows still open
http://www.impaks.com/images/ken/dodge/DSCN5177.JPG
pic showing inside
http://www.impaks.com/images/ken/dodge/DSCN5180.JPG
rudie59 Feb 2, 2015 01:01 AM
Mirror mounts
Wondering if it's possible to get u to make a set of mirror mounts for my first gen.
j_martin Feb 2, 2015 10:01 AM
Perchance we could get a drawing with dimensions. This is a mod I'd like to do soon.
rudie59 Feb 2, 2015 10:53 AM
Hoping bruiser will respond to thread comment L Martin otherwise if u stumble apon a way to do it or mount by chance could u let's know would be lend a helping hand I live right down in ham lake and see that ur from isanti.
bobva Feb 2, 2015 11:25 AM
I wouldn't my breath . bruiser hasn't posted in years.
