high oil pressure reading, high coolant reading
the truck in my sig has a high oil pressure reading right at the highest bar and coolant is bouncing between half and highest bar, but i can touch rad its hot on the intake side and cool on return, i take rad cap off and does no burst out nor is it bubbling like a head gasket compression leak, and upper coolant tube is warm so it is circulating. what do you guys think could be doing this? bad ground somewhere?
Thanks, Gregg |
Definately sounds like a bad ground. Start by checking the one that goes from the battery to the cab Ive seen it go bad alot. :) good luck
it was a ground problem for sure! fixed it :) now next problem, where can i find body mount bushings? mine are cracked and in really bad shape! also who makes a good power steering gear box for these first gens, mine has a lot of play before it even moves the pitman arm.
thanks, Gregg |
Here's one that looks real good
http://www.pscmotorsports.com/vehicl...harger?cat=282 |
looks like that will be the way to go, i wonder what the ratio of the box is?
| All times are GMT -5. The time now is 03:37 AM. |
