HID's flickering while on running lights only.
Old Apr 25, 2011 | 08:50 PM
BILTIT's Avatar
So i upgraded to HID's and love it! But, i noticed when the running lights are on the headlights flicker at a very high frequency, this stops as soon as i turn the headlights on. I am assuming that the running lights have less than 12v which is in turn causing the HID's to flicker. Is this correct? Is there a way to get full power to the lights while on running lights only if this is the problem? I dont think i have a lighting schematic, etc.
Old Apr 25, 2011 | 08:58 PM
sooty's Avatar
check volts under load, at the supply, those use low power, but are like fluorescent tubes, with high voltage ballast, that affects everything close by, you havent done the h/light upgrade, that circuit is already max/taxed without adding anything, stocker h/light voltages could recede below 9 volts running. sticky has relay upgrade.
Old Apr 25, 2011 | 09:04 PM
93flatbed's Avatar
Do the relays as sooty said. I noticed a difference on my hid's after installing relays.
Old Apr 25, 2011 | 09:08 PM
sooty's Avatar
youll be blown away at your stock light performance. especially if you add a tie to allow hi an low beam run together.
Old Apr 25, 2011 | 09:35 PM
BILTIT's Avatar
I had figured that since the HID's are supposed to use less power while running they would tax the lighting circuit less. I have done relay upgrades on other vehicles so that will be an easy one. I will also check voltages.
Old Apr 25, 2011 | 09:38 PM
torquefan's Avatar
If you have daytime running lights, they will need to be disabled for your HIDs to work properly. The low voltage they operate with won't operate a relay correctly either.
Old Apr 25, 2011 | 10:30 PM
BILTIT's Avatar
I wondered about that, any idea what voltage they run at? I can measure it tomorrow.
Old Apr 26, 2011 | 10:01 AM
Rampage1967's Avatar
I did that with a set of GE HO Halogens years ago.
I have to agree that it makes for crazy brights.
The dims were also a huge improvement be honest.
Old Apr 27, 2011 | 07:18 PM
RuralCruiser007's Avatar
When your DRLs are on your headlights are running at 60% duty cycle. That is the cause of your flickering.
Old Apr 28, 2011 | 12:16 PM
BILTIT's Avatar
So can i just unplug the daytime running light module?
Old Apr 30, 2011 | 03:39 PM
New_Dog93's Avatar
If you do this then you will defeat the DRL but the high beam indicator light in the dash won't work any more. I had to cut a couple of wires outside the module and then splice two back together to get it to work right. I'll take a pic of the mod and post it.
Old Apr 30, 2011 | 04:15 PM
BILTIT's Avatar
Ok thanks. I don't really care about the DRL's but want the high beam indicator to work.
WhozNxtLS1
Dec 28, 2008 02:45 PM
Common
Aug 7, 2006 08:56 AM
PapaPerk
Mar 13, 2006 09:14 AM
Palmetto_kid
Mar 14, 2005 10:07 AM
Lil Dog
Feb 21, 2004 12:44 AM
