Help: What is this sensor?
Old Jul 21, 2021 | 08:11 PM
Mick-e's Avatar
See attached
left side of engine below fuel filter
Hopefully something I can order.
In all of the pump removal tutorials they say to remove the top 2, and bottom bolt from the pump support bracket, and rotate it backwards, but don't mention to be careful not to shear off the sensor sticking out.
I tried to remove what's left, and it appears to be a 1-1/16 but it didn't budge so I left it alone for now.
Thanks
-mickey
Old Jul 21, 2021 | 09:15 PM
That is the oil pressure sensor.
Old Jul 21, 2021 | 09:17 PM
Mick-e's Avatar
Thanks Oliver.
So I can run the engine without it, but I'll get a low oil pressure warning, or no pressure on my gauge?
How do you get it off?
Old Jul 22, 2021 | 03:45 AM
KRB's Avatar
KRB
I don't know the size but there's a good chance it could be metric, did you try that for a better fit?
Maybe running it to warm up temp may help free it us some.
Old Jul 22, 2021 | 07:26 AM
nonrev's Avatar
Super Moderator
10 Year Member
There is actually a special socket for that and it's not very expensive
Old Jul 22, 2021 | 10:04 AM
Mick-e's Avatar
And when I ordered the switch conveniently is this suggested option
https://www.napaonline.com/en/p/BK_7...670&ir=1&tps=4
Chrome vanadium socket removes 2 3/4" deep oil pressure switches requiring 1 1/16" hex. Can be used with 3/8" or 1 1/8" drive wrenches. Length 3 1/4"
This socket is narrower, and longer than the 1 1/16 impact socket I have so I'll get this, and the switch, both in stock at the local Napa today, and hopefully put it all back together.
Thanks everyone for the help and quick replies
Jthrash
Apr 15, 2019 01:54 AM
coppertop762
Feb 23, 2019 05:06 PM
wildcat
52
Oct 15, 2008 06:57 PM
cbrahs
69
Aug 8, 2007 10:40 AM
cditrani
13
Feb 4, 2007 03:35 PM
