Help- installing converter in 727- now
Is there a magic number of a measurement from face of bellhousing to lug on the torque converter. It has been way too long since I have done any Mopars. When I put this converter in the 727 and I turn and turn it, but it won’t go back any further than barely flush when installing. I can see by the difference between the flexplate and the back of the engine that it needs to be below flush at least a little.
I had a measurement of 1-> 1-1/8” on GM, and that always meant is was all the way engaged in the pump, THEN I could pull it forward to bolt up to flexplate and wound up with ¾”.
Does putting the 727 trans into a certain position help- like Nuetral vs. Park?? Thanx, Crossy
My method is to use the heel of your hand to lightly push and spin the converter in a clockwise direction at the same time in one motion. You should get two audible clunks when fully seated. The standard measurement for a gas engine was 1/2". Not sure that's the same on a diesel and I know for dang sure it's not on a diesel with a lockup converter as they still protrude from the bell housing face when fully installed.
Putting the trans in different gears won't help one bit.
corye
06-22-2009 01:52 PM
wcialrlter
04-26-2006 10:47 PM
