Help! Front Spring Replacement
Old Mar 6, 2010 | 04:34 PM
mhuppertz's Avatar
I'm trying to replace my front springs, but the old ones are still under pressure, even with all the u-bolds loose. the only things left are the shocks, but the FSM doesn't say to remove them.
Can't figure it out...
Old Mar 6, 2010 | 04:38 PM
rebal's Avatar
take the shocks off and jack up the frame that will take the load off
Old Mar 6, 2010 | 04:43 PM
mhuppertz's Avatar
I do have the whole truck raised by the frame, so maybe the shocks are still holing the axle up. I'll try to get them off, but they don't want to!
Old Mar 6, 2010 | 04:47 PM
rebal's Avatar
the shock keep the axle from over extending. I have see trucks get air born and ether snap the shock off or the mount !
Old Mar 6, 2010 | 05:03 PM
mhuppertz's Avatar
I'm having troble getting the shocks to come loose. I feel inept...
Old Mar 6, 2010 | 05:04 PM
93flatbed's Avatar
You cant be the nut off or you have the nut off and can't slide the shock off? Is your axle still hanging by the shock only?
Old Mar 6, 2010 | 05:10 PM
mhuppertz's Avatar
I have the nut off and can't get the shock loose from the top mount. I tried jacking the axle back up. I screwed up by not taking the shocks loose first.
Old Mar 6, 2010 | 05:24 PM
93flatbed's Avatar
Well sounds like you are either fighting gravity or fighting rust. You may have to find the right spot for the axle to "droop" down so you can slide the shock off. May want to soak it in WD then go inside for a soda. Then come back out and give it another try?
Old Mar 6, 2010 | 05:58 PM
TIMMY22's Avatar
Cut the old shock in half, then beat the two ends off.
Old Mar 6, 2010 | 05:59 PM
TIMMY22's Avatar
You think that's fun, try getting the bushings out of the spring eyelets.
Old Mar 6, 2010 | 06:07 PM
speed75's Avatar
You said to beat the shock off that's funny
Old Mar 6, 2010 | 06:11 PM
mhuppertz's Avatar
Got the old springs off, but the replacement springs (off of a 1990 W250 Diesel) have the smaller, rear bushing size on both ends. I'm going to have to find two more bolts and snug it down really well until I can afford to get my original springs re-arched and re bushed. This is less than fun, but at least I won't be eating tires in the front anymore.
Old Mar 6, 2010 | 06:32 PM
TIMMY22's Avatar
I guess it depends on how you interpret it.
Old Mar 6, 2010 | 06:35 PM
mhuppertz's Avatar
sick................
Old Mar 8, 2010 | 08:51 PM
mhuppertz's Avatar
Got it done Sunday. Ended up using my top springs (the clamped ones) and the bottom spring set from the replacement springs (and added a leaf). I got probably upwards of two inches of lift out of the deal, and the front end feels so much better, and all the poping during steering is gone. Makes my kidneys explode over speedbumps, but it's better. I need to quad shock the front now...
viper
Aug 3, 2019 01:21 PM
jmkord8703
Sep 7, 2010 05:21 PM
whosdunit
Apr 14, 2010 09:57 PM
ric o'shea
Mar 10, 2009 02:37 AM
u.s mma
Jul 15, 2007 08:34 PM
