Help!
I was adjusting trans bands and the manual says to back off lock nut 5 turns.I needed to back it off way more to get the adjuster to click 72 inch pounds. I had to run the adjuster way in before it would hit 72 and then backed off the proper turns. Is this right? Are my bands way out or worn badly? ---Or---- should I have backed out 5 on the nut then turned them both back 5 in and set it to 72 in lbs then snug nut to 25 ftlbs?
Also is brown fluid the result of excessive clutch material worn into the fluid? My fluid was brown. |
Sounds like it was badly out of adjustment. Back off the locknut as much as you need to tighten the adjuster. The main thing is that it is the band that is getting tight and not the locknut while you are torquing.
Excellent, thanks!
Also, it doesn't seem like i will get another adjustment out of the screw. What's next or how long till the next adjust? |
Originally Posted by powerrammaster
(Post 2679094)
Excellent, thanks!
