heater problems
Old Jan 30, 2009 | 07:35 PM
The_Head's Avatar
heater problems
My blower motor wont blow no mo. But, the fuse (#11, 30A) is not blown..
Hot air comes out when the a/c button is pushed.
What has gone wrong?
Old Jan 30, 2009 | 07:58 PM
ofcmarc's Avatar
The switch or the resistor. Most likley the switch. A bad resistor will "normally" cause a low speed only situation. Bad switch- no nothin'
Neither one is very expensive. But I believe the resistor is Dealer only.
If you have to go into the dash for either. Jim Lane's Heater on relay trick isn't too bad to do and well worth running the wires while you are in there.
Old Feb 1, 2009 | 08:46 PM
The_Head's Avatar
Thanks for the advice, I will look up his writeup on the heater.
Old Feb 2, 2009 | 04:38 PM
ofcmarc's Avatar
You will still have to fix the heater problem before you do the relay trick. The relays only effect the "HIGH" setting. The 3 lower speeds are still controlled by the factory wiring.
Old Feb 12, 2009 | 08:00 PM
The_Head's Avatar
well I got the switch out of parts truck to swap over. Someone had a plastic tie keeping it secured to the heater.
So, lo and behold, I found the reason mine wasn't working was because it had worked it's way loose from the socket.
Old Feb 13, 2009 | 02:01 PM
ofcmarc's Avatar
Quite possible that was there from the factory. I've seen a lot of them that way. glad you found the problem.
rjm022
Dec 11, 2019 09:17 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
modiesel
Mar 7, 2008 10:44 AM
taildragger
Dec 4, 2006 10:00 AM
Reelay
Dec 1, 2005 06:14 PM
