Heater on 1993 3500 stuck on hot
Hi There,
I have a 1993 3500 5.9 cummins and heater is stuck on hot. I noticed when i first start out there is steam coming out of the vents and windsheild would fog up a little, After awhile it would clear up. The previous own had the hearter core replaced about 1 1/2 year ago? Suggestion where to start of a fix? I do need heat in the winter but not now.
Thanks
Thanks
When you start he truck have someone watch your A/C compressor, does it cycle on for a minute or two? I know the newer cars the A/C cycles to clear the humidity from the heater and A/C cores.
But I can't see it being steam when the truck isn't even warm yet.
Not sure on the 92/93's but doe they have a cable control for the temperature blend? I know when I got my 87 ram it had a cable control and the cable was seized on wide open heat. Replaced the cable and all was well.
Not sure if it is cable control I haven't had a chance to take apart.
I might have to agree on heater core for the steam. I have heard of guys placing a shut off valve for on hoses prior to the heater core but would rather get the proper fix.
Thanks
Thanks
Strjock81
16
Dec 12, 2007 09:53 AM
duallydave
Aug 7, 2005 09:38 PM
