-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   hear sucking when loosening the filter? (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/hear-sucking-when-loosening-filter-136469/)
blueberry 02-10-2007 12:58 PM
Hey all,
Power is not what it was yesterday. As I loosened the fuel filter I heard sucking. I am thinking this means the system is sucking in air causing a vacuum at the highest point in the system?
Brian
wannadiesel 02-10-2007 01:41 PM
It sounds to me like there is a restriction somewhere in the suction line. But we've been through all that before. :confused: Don't you have a whole new line and pickup at this point? Perhaps the truck cursed... [coffee]
blueberry 02-11-2007 09:10 AM
When I replaced the fuel heater I probably didn't get the O-ring tight enough?? I was able to move the heater back and forth by grasping the plug and tugging on it without much effort. I tightened it down again. This time I didn't use a gasket scraper, I used something similar to a brake sppon that has 4-5" of long handle to give more leverage. I wasn't sure how far to go because I didn't want to brake the fuel heater, but its probably tighter than before. How likely are the fuel heaters to brake?
Brian
