to the head timing???
Old May 6, 2008 | 12:21 PM
dodgetrucker75's Avatar
yesterday i advanced my pump all the way... i have heard a lot of good results from doing this, but it killed mine... i fell like i lost a lot of power and it droped my max boost about 15 psi... also when using the water/meth i can barly fell any power as before it would set you back in the seat. for now i am going to put it back down, but does anyone know why me results are so different? is it just my set up? is there a setting that i should be set too? let me know...thanks guys
Old May 6, 2008 | 05:53 PM
Sounds like it was too much. There is a lot of variation in the position of the pump at stock timing, some of them are further out from the head than others.
Most guys running the pump up against the head have POD's. They are nasty slobbering injectors with the wrong spray pattern so they like lots of timing - but they make a lot of power for very little money.
Old May 6, 2008 | 09:07 PM
rebal's Avatar
I wouldn't run that much timing with water meth. water meth advances the timing even more. head gaskets will suffer with to much timing and lots of fuel and high boost. is your bucking like johns?
PS. don't believe him I didn't give him that idea .like wanna said diff . pump sit on the engine diffrantly
Old May 6, 2008 | 10:59 PM
w250_93's Avatar
will too much timming make the motor seem like it is missing
Old May 6, 2008 | 11:15 PM
99globalwarmer's Avatar
yes it will hop and skip i advanced mine a tooth and it did alright but then i did injectors really big ones so it balanced out, then the gasket blew and then oringed now no worries but yes wanna is definetly right the stock timing differed so it could have been to much timing, you just need some sticks and your good
Old May 6, 2008 | 11:16 PM
GLHS's Avatar
Your boost will go down but the top end will scream, rpm wise, especially if you have a gov. spring.
Like wanna said, on some trucks it is too much.
You didn't happen to break the afc boost tube in the process did you?
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
