head gasket off
Old Mar 11, 2009 | 05:53 PM
grandpa ralph's Avatar
head gasket off
I chickened out and am paying someone to do the head gasket, but thought I would share the pics and experience so it might help someone down the road.
My gasket wasn't actually blown. Head bolts stretched and/or nuts loosened. there was cylinder to cylinder leaks as well as the coolant coming out behind the heat exchanger
here's the leak
here's the old gasket
everything off
head
Old Mar 11, 2009 | 06:37 PM
Based on what the mechanic suggested:
1. Head gasket set- P/N 4089649 213.00 includes turbo/exhaust manifold gasket, manifold bolts and gaskets, injector washers, etc
2. 4 turbo studs and nuts
3. 26 head bolts
Bolts P/N 3920779 6 @ 3.35
3920780 14 @ 4.43
3920781 6 @ 7.22
4. exhaust manifold $350
5. Upper and lower radiator hoses
6. new belt
7. Updated Thermostat for 89-93 models and gasket
Cummins Part# 3802968
and from searching here:
8. oil cooler 3957544 $279
9. fuel heater gasket
Cummins P/N 3913695
10. Oil Psi Sender
Cummins Part# 3923200
total is $1100 from cummins +$140 for hoses and belts at napa
Old Mar 11, 2009 | 06:45 PM
DNRCustoms's Avatar
Ouch... Your oil cooler looks good, your whole side of the motor looks real good, very little rust... Is your cooler leaking??
Old Mar 11, 2009 | 06:50 PM
no cooler leak. wiped it with a clean rag a few times looking for the initial leak.
Old Mar 11, 2009 | 06:59 PM
DNRCustoms's Avatar
Well, on my dump truck.. the line that runs around back of the cooler and loops to the elbow rusted through.. It was a bugger to find out where it was coming from... That whole cooler deal is a PITA, if it leaks again I am tossing it on both of my trucks..
Old Mar 11, 2009 | 07:57 PM
archer39's Avatar
yes it is. My one line rusted out (coolant) this summer and i ended up replacing it with rubber hose. It is so tempting right now with the downpipe out of the way to just pull the whole thing out.
Old Mar 12, 2009 | 08:00 AM
apwatson50's Avatar
If you're going to spend 350 on a factory exhaust manifold, might as well spend 450 for a 3 piece.
But why, is it cracked?
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
