head bolts
Old Dec 30, 2007 | 12:21 PM
SMOKE' EM's Avatar
head bolts
whats the torque for the head bolts
Old Dec 30, 2007 | 02:33 PM
Montana2x2's Avatar
From 1991 FSM Step1 29 ft/lbs, Step2 62 ft/lbs, Step3 93 ft/lbs
Old Dec 30, 2007 | 03:30 PM
BC847's Avatar
1st Generation Admin
That's odd, the '93 FSM says ~
Pages: 9-115 & 9-116 (5.9L (Diesel) Engine)
Old Dec 30, 2007 | 04:04 PM
rbrettctd's Avatar
91 manual is nonintercooled, slightly different head (9mm) and a weaker HG from what Ive heard...Im not sure if they had an FSM for IC 91s.
Old Dec 30, 2007 | 04:08 PM
mhuppertz's Avatar
Originally Posted by BC847
That's odd, the '93 FSM says ~Pages: 9-115 & 9-116 (5.9L (Diesel) Engine)
Sorry for the hijack, but where is the best place to get an FSM?
Mark
Old Dec 30, 2007 | 04:20 PM
BC847's Avatar
Mark
http://www.genosgarage.com/prodinfo....r=DFSM93_PRINT
So what year is SMOKE' EM's truck?
Old Dec 30, 2007 | 04:34 PM
mhuppertz's Avatar
Thanks, ordered it (FINALLY!).
Old Dec 30, 2007 | 04:56 PM
JD730's Avatar
The reason it in 1991 the certification changed on the engine and they changed the head bolts to a different design. 1991 and prior bolts SHOULD NOT be used in 1991 and later engines, but 1991 and later bolts can be used in the older engines.
The old bolts are a straight torque style one, the newer one is a torque plus 90*. Look at the head of the bolt and you will see T<90 on the newer ones, earlier ones do not have this and should not be torque that way either.
Old Dec 30, 2007 | 05:22 PM
rbrettctd's Avatar
IIRC he has a 92 or 93 , which would be the specs BC847 gave
Old Dec 30, 2007 | 08:30 PM
SMOKE' EM's Avatar
it is a 93
Old Dec 30, 2007 | 11:34 PM
BC847's Avatar
Ah Ha! I read something recently concerning the bolts and didn't know the connection. Thanks Mike.
1985cucv
Jul 6, 2009 04:38 PM
benroberts3605
Nov 4, 2008 10:30 PM
Conn
Dec 29, 2006 06:30 AM
Dusty Ratcliff
Apr 10, 2006 07:35 AM
MADSEN
Oct 7, 2004 09:43 PM
