Hard starting
Old 07-15-2018, 09:26 PM
cabtruck's Avatar
Hard starting
Iv got a 93 I did a frame swap D to W conversation while I was doing the swap I fixed problems from previous owner. He installed a electric fuel pump. I put it back stock engine lift pump now it has to spin over to start. I’ve checked for fuel Suction Leaks any other ideas could it be something in the injection pump that the electric pump is hideing
Old 07-16-2018, 02:46 PM
searcher's Avatar
If you have positive pressure at the IP, inlet it should start easily. As long as there are no other problems like air in the lines or a fuel leak.
Old 07-16-2018, 02:59 PM
cabtruck's Avatar
Only thing that I changed was got rid of the electric pump and replaced the factory lift pump now it spins 10 to 20 seconds before it hits then runs ruff for a second or two I’ve checked it for leaks can’t find anything
Old 07-16-2018, 03:27 PM
Received 2,392 Likes on 1,576 Posts
I bet it has a leak in the fuel line somewhere from the fuel pick up to the LP.
When it sits the air gets in the line as the fuel drains back to the tank. When you start it, it has air in the line. That would cause the exact thing you describe.
Old 07-16-2018, 04:17 PM
cabtruck's Avatar
Any ideas for finding it
Old 07-16-2018, 04:32 PM
Pressurize the fuel tank with 2 PSI or so of air pressure from an air compressor.
Then check for fuel leaks.
You see the problem will be that when running the truck that section of fuel line is under negative pressure and will draw air, so it will never show wet spot of fuel.
Pressurizing the tank should make a wet spot in the line.
The following 3 users liked this post by oliver foster:
edwinsmith (07-16-2018), MrFusion (07-18-2018), nothingbutdarts (07-16-2018)
Old 07-16-2018, 06:11 PM
cabtruck's Avatar
I’ll try and see what happens
fourthandgoal
88
12-27-2011 05:39 AM
RED99CTD
04-20-2011 08:08 AM
abc4yew
03-15-2007 11:55 PM
L. D. Bryant
11-17-2002 12:18 PM
Quick Reply: Hard starting
