H1C Options
Old Apr 25, 2012 | 07:25 PM
BILTIT's Avatar
Its just a matter of a smaller housing usually causes higher egt's when pulling for long durations although the 351 has a larger throat so it can expel gases faster then the previous years turbos. Should keep the egt's down.
Old Apr 25, 2012 | 08:25 PM
1972RedNeck's Avatar
I will use a 14 cm housing on my turbo. Where can I get a 60 mm compressor wheel?
Old Apr 25, 2012 | 10:13 PM
BILTIT's Avatar
http://www.gillettdiesel.com/H1upgra...wheel60mm.aspx
Old Apr 25, 2012 | 10:27 PM
So I can't buy just the wheel? Or will the compressor housing help performance?
Old Apr 25, 2012 | 11:07 PM
BILTIT's Avatar
You need the housing with the wheel, they are a matched set.
A 60mm wheel will not fit in a 54mm hole (compressor housing).
Old Apr 26, 2012 | 11:19 AM
brainfade's Avatar
You can machine the backing plate your self if you have access to a lathe. I did my own and the setup and cut took less than 30 minutes once I had it all apart. But Biltit's right that the housing and wheel are matched.
I used HTT parts because that's what was available when I did mine but the Gilette parts are the same thing and usually a little cheaper.
Old Jun 24, 2012 | 09:47 PM
More questions:
I am thinking that I want to go with a 12 cm waste gated housing. The HE351CW has a 4" exhaust outlet, correct? What size outlet does THIS have? (Or is the outlet the side with 4 bolt holes?) If I can get one with a 4" outlet it will help keep my EGT's down, correct?
Old Jun 24, 2012 | 10:05 PM
BILTIT's Avatar
Yes the 351cw has a 4'' outlet, that housing has a standard 3'' outlet.
A 4'' will help with EGT's VS the 3'' outlet, how much is harder to tell.
Old Jun 25, 2012 | 01:01 PM
Moparbubba's Avatar
He351cw have a 4.4 downpipe flange its larger then the hx40 4inch downpipe. I had to use an adapter flange to step down to fit my 4in de downpipe
Sent from my DROIDX
Old Jun 25, 2012 | 02:56 PM
Is there such a thing as a 12 cm waste gated housing with a 4" or 4.4" outlet?
Old Jun 25, 2012 | 03:00 PM
Moparbubba's Avatar
The 4.4 is on the he series and its the flange size.
I believe the smallest 4 inch that holset made was a 16cm for the super 40. Aftermarket idk.
Sent from my DROIDX
Old Jun 25, 2012 | 03:06 PM
Moparbubba's Avatar
If your are keeping the h1c its gona be 3inch out far as i know no one makes a exhaust housing with a hx40 style outlet for them.
the diamond eye kit that is 4 inch has a h1c flange on it even though its 4inch.
If you step up to a hx40 or s300 itll be 4 inch then you have to get a hx40 style downpipe de sell those as well as source auto.
And if you go to the he351cw its slightly larger i used a clamp on adapter from 4.4 to 4 inch.
Sent from my DROIDX
sammy340
Sep 23, 2004 05:13 PM
Rales
Aug 8, 2003 12:59 AM
DeereDiesel
Aug 7, 2003 10:17 PM
Alec
Aug 5, 2003 02:43 PM
