Grid relay specs
Old Feb 1, 2010 | 12:33 PM
oly_fab's Avatar
Grid relay specs
Does anybody know what the heatergrid relay specs are? I keep burning up my relays on my warn winch (yes I use it ALOT) and I got to thinking that the relays on our trucks might work.
Stu
Old Feb 1, 2010 | 12:37 PM
RSWORDS's Avatar
Here is the section from teh FSM that deals with them, It should have the specs, Hope it helps!
http://www.dieselbombers.com/1st-gen...id-heater.html
Old Feb 1, 2010 | 04:54 PM
Trebor's Avatar
They are rated at 100 Amps with a 400 Amp inrush rating.
http://www.stancor.com/wrdstc/pdfs/C.../Pg_052_53.pdf
Mouser Part #: 802-120-901
Manufacturer Part #: 120-901
Supplier: Mouser http://www.mouser.com
$16.64 each.
Old Feb 1, 2010 | 06:41 PM
oly_fab's Avatar
Thanks guys just what I was looking for.
Stu
Old Feb 1, 2010 | 10:27 PM
Jim Lane's Avatar
They are made by White Rodgers and rated at 100-amps, There is also a 200-amp version of this solenoid.
I get my solenoids from Grainger’s.
You can parallel 2 solenoids to handle more current.
What is burning out, the coil or you welding the contacts?
How is you battery voltage when the winch is running?
The lower the voltage the more amperes it will draw.
Larger winches will draw many hundreds of amps when they stall far exceeding the contactors rating.
Jim
Old Feb 1, 2010 | 10:39 PM
feets's Avatar
What kind of amperage can you run through the old school Ford starter relays? Will they be any better than grid heater relays?
Old Feb 2, 2010 | 03:34 AM
Jim Lane's Avatar
Maybe 75-100 amps but the solenoids are only rated for intermittent duty and will get extremely hot and burn up in a matter of minuets.
You need one that is rated for continuous duty as our solenoids for our grid heaters.
I also use these to interconnect batteries on my truck.
They would probably work ok for the grid heaters because they only cycle intermittently anyway but not for anything continuous like a winch motor or battery interconnect.
http://www.grainger.com/Grainger/items/6C017?Pid=search
Jim
Old Feb 2, 2010 | 07:43 AM
oly_fab's Avatar
Jim
Jim I'm not sure what is going out yet( first one I just replaced the whole box) this time I'm fixing it so it dont happen again.
I have duel redtop optima's. Pretty sure I'm good there. Ive never stalled this winch, last pull before it died I yanked a cherokee out of a bolder pile. It sucked it down hard but never stalled.
The stock warn solenoids are not continuous duty. I was looking at the albright and the titan solenoids but thats around $200( 1 solenoid controls it all).
Stu
rgadagno
Mar 11, 2005 09:53 AM
Geico266
Jan 8, 2005 06:39 PM
hobbyman
Feb 13, 2004 03:23 PM
mazeppa
Feb 10, 2004 06:54 PM
midwestdually
Jan 19, 2004 11:25 AM
