Grid Heater Weirdness
I noticed a weird issue with the grid heaters on my truck.
When the temps fall into the twenties or less, the grids do come one, as I can see the volts on the guage drop and I hear the relay click, then relase when the wait to start light goes out.
I start the engine, and then there is no cycling with the grids.
If the ambient temp is above freezing then the grids will cycle.
Is there a temp sensor that may be going out?
Thanks!
Thanks!
The temperature sensor only tells the box to start the sequence which is pre-programed. My best guess is you have a problem in the box. Something effected by temperature like a cold solder joint or cracked trace on the board.
bigwheels94
13
Mar 1, 2009 02:27 PM
v8440
Jan 25, 2006 07:28 AM
