Got a wiring problem HELP!
Old Oct 27, 2008 | 07:43 PM
Murphy85's Avatar
Ok I was driving lastnight and the radio, and all the interior lights went off.
The headlights, gauge illumination, blower motor, windows and mirrors all work. the headlights also went dim like the alternator was'nt running. got it home and turned it off and now it wont turn over at all. seems like the ignition is not getting power but I checked the fuses and they all looked good. Any ideas?
Old Oct 27, 2008 | 07:48 PM
2stroke's Avatar
did u check the fuseable links @ the battery? oh and i would chrge up the battery. sounds like ur charging sysetem quit!
Old Oct 27, 2008 | 08:56 PM
Murphy85's Avatar
Ya everything quit pretty much I will check the fuseable links. Any other ideas?
Old Oct 27, 2008 | 09:22 PM
Murphy85's Avatar
Just checked the fusable links, there is only two on the inner fender right? They all have 13 volts and the fuse box has 13 volts going into it. I think it might be the ignition switch but I dont understand how the windows still work when nothing else does?
Old Oct 27, 2008 | 10:49 PM
Tron's Avatar
The ignition switch has a few circuits in it so it is possible.
Old Oct 28, 2008 | 11:03 AM
Murphy85's Avatar
So with the ignition in the on position you are saying the windows could work but the stereo and gauges would not? I dont want to buy an ignition switch and have it not be the problem.
Old Oct 28, 2008 | 04:30 PM
Murphy85's Avatar
How many power wires go into the ignition? Only one in the center or is there more?
Old Oct 28, 2008 | 04:37 PM
Two wires feed the ignition switch. One is red, one is pink & black.
Old Oct 28, 2008 | 07:02 PM
Murphy85's Avatar
Ok thanks. The red wire to the ignition switch is dead. When I jumper it everything works fine except no cranking, and no click when I try to hit the starter. could all this just be the starter relay?
Old Oct 28, 2008 | 09:14 PM
Murphy85's Avatar
Ok I just checked and I have 12 volts comming out of the ignition to the starter so im thinking it is the relay.
Old Oct 29, 2008 | 07:32 PM
The red wire coming into the switch gets power from one of the fusible links on the fender. You have a blown fusible link.
Dale M
Mar 5, 2011 03:40 PM
Evildiesel
Jul 2, 2006 06:39 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
charcoal600
Apr 30, 2005 02:34 PM
