glow plugs squeel
Old Nov 24, 2007 | 08:30 PM
mullishacrew's Avatar
glow plugs squeel
well the past couple months when i go to turn the truck on and warm the glow plugs up in this northern BC cold winter the glow plug wiring from the battery to the heavy wires seams to wine real loud, but they still work, any one know what this could be?
Old Nov 24, 2007 | 08:38 PM
iker42's Avatar
U dont have glow plugs
Old Nov 24, 2007 | 09:14 PM
Beats me why the grid heater circuits sing, mine do that sometimes too. Maybe one of the electrical gurus has an idea. Jim?
Old Nov 24, 2007 | 10:28 PM
TruckU's Avatar
mine's done that from the time I bought it, I assumed it was a normal thing...
Old Nov 24, 2007 | 10:32 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
UHHHHH.....glow plugs?????? Cummins never had 'em.
Old Nov 24, 2007 | 10:47 PM
CaptainChrysler's Avatar
I have not noticed mine doing it. Do you supose the "grid" is vibrating while it warms up?
Old Nov 24, 2007 | 10:54 PM
jogl's Avatar
Mine hums too, and I never thought about it, but when it is all DC there should not be a humming. Maybe it is the relay acting like a buzzer(?)
As mentioned we have grid heaters that heat the intake air, not glow plugs which are found mainly in the prechambers of IDI engines.
JP.
Old Nov 24, 2007 | 11:26 PM
Jim Lane's Avatar
Maybe a bad connection in the cable, do a voltage drop test between the (+) battery terminal and the solenoids.
You want to check from one end of the cable to the other terminal to terminal and see what reading you get.
It shouldn't be too much. Also you can check the solenoids, they might have burned contacts and you are hearing them arc.
When you are drawing heavy currents through a cable they can make noise because of the magnetic field that is being produced.
This is why an Induction Ammeter works the way it does.
If you do not have one of these it is a good diagnostic tool to have, I have a few tricks on using them.
When anything heats up by way of a current passing through it does not do it peacefully, the element is expanding, creaking and contorting itself as it heats up.
Jim
http://globalepower.com/Datasheets/Hoyt/Induction.pdf
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Nov 25, 2007 | 11:40 AM
TruckU's Avatar
Mine is more of a whine, not a pop, creak, or groan. pretty high pitched, adn like I said, it's been there the whole 74K that I've had the truck.
Old Nov 25, 2007 | 12:46 PM
DODGE 92's Avatar
intake heaters
mine does the same thing dont worry about it
Old Nov 25, 2007 | 07:34 PM
Bookshelf's Avatar
I've had 10 firstgens and every one has done this.
Old Nov 25, 2007 | 07:45 PM
ohh ok, it jsut seams odd gthat all of a sudden they do it, but thanks again guys! now i dont gotta think it will burn to the ground because of a short from that haah
Old Nov 25, 2007 | 08:57 PM
RumbleFish's Avatar
My first one did this a time or two. As far as the crew cab, with the awesome wiring done by the previous owner, I only heard them work a time or two.
Hillbilly_Deluxe
Sep 24, 2005 03:38 PM
jlasich
Feb 9, 2004 06:13 PM
TheMoose
Nov 13, 2003 03:32 PM
kingofdodge7131
16
May 14, 2003 02:19 PM
FastSS
Dec 22, 2002 01:48 AM
