Getrags on the Bay
Old Sep 18, 2010 | 02:15 PM
maybe368's Avatar
Getrags on the Bay
There is an outfit selling both 2 and 4wd getrag 360s on evil bay. Just search getrag 360 and it will come up. It looks like a real good deal, completely remaned and 1 year warranty. In Indiana somewhere. Does anyone know about these? Mark
Old Sep 18, 2010 | 06:13 PM
GIT-R-DONE's Avatar
I have also been eyeing those up, actully emailed the guy to see if there is a core charge and if there is....how much. I dont have a sper to give them is why I was asking. I have never bought from the seller before. I will have to wait for a response.
Old Sep 18, 2010 | 06:46 PM
maybe368's Avatar
Great, let us know the scoop ...Mark
Old Sep 18, 2010 | 08:32 PM
93flatbed's Avatar
Maybe368, there is a Nv4500 4x4 for sale local. Don't know if you want to go that route but the dude doesn't want much for it. And I'm not selling it, just thought I would say something.
Old Sep 19, 2010 | 09:10 AM
1993 250bluebal's Avatar
I just e-mailed this guy on e-bay about referances for his work, and told him that it looked like he does it out of his garage due to the pegboard background and his work bench. I'll post his responce. Yea, it's evil bay and the internet, a good paint job and some sawdust will make ant tranny sound and look good.
Old Sep 20, 2010 | 09:20 AM
GIT-R-DONE's Avatar
Response I recieved today:
"The price without a core is $1595.00. We are located in Indianapolis. Thanks for looking."
I know I called the dealer for a quote on a rebuild and they said it was like just 1200 $$ for a bearing kit. Now, thats a dealer and I know the bearing kit/rebuild kit isnt that much.....so I dont know which way to go. It is hard IMO to find these used in good shape.
Old Sep 20, 2010 | 10:54 AM
maybe368's Avatar
Seems to be a great deal if they stand behind their 1 year warranty.
like you said these don't seem to grow on trees Mark
Old Sep 20, 2010 | 06:50 PM
This is the response to my e-mail.
Dear unclenicknack1,
Hi,
Yes we build the 4x4 transmission's also. The core charge is $500.00. We have several parts suppliers we use and they sell good quality parts and name brand bearings. We shim these transmission just right and have no problems with them. We've been building manual transmissions for over 17 years. If you have any questions please feel free to call. Thanks for looking.
I think its a little spendy
The place i'm going to get my parts from and do it myself is this-----
Zumbrota Bearing and Gear Inc.
622 West 1st Street
Zumbrota, MN 55992
1-507-732-7994 or 1-800-658-2537
Fax# 507-732-5432
Open Monday-Friday
8:00am to 5:00pm Central Time
Old Sep 20, 2010 | 08:35 PM
oilcan64's Avatar
i forget the fellas name, i think it was mystery man. but he used to work for chrystler building the getrag or something like that. i read it in a post on here. he knows a lot abt it. he said that the only reason dodge went to the nv4500 over the rag was b/c it was cheaper. if i ever i need to have my rag rebuilt id contact him because he seemed very knowledgeable abt the getrag
Old Sep 20, 2010 | 08:38 PM
Yea he built them back in the day, Pretty sure he's banned on this forum though.
Old Sep 20, 2010 | 08:42 PM
oilcan64's Avatar
found it here. https://www.dieseltruckresource.com/...al-t99773.html
mysteryman wrote:
The bearing that fails is the rear main shaft bearing.....This happens due to some of the things I mentioned earlier in this thread....
What you have is a Timkin tapered roller bearing pressed onto the main shaft.....the race is then placed into the rear of the case partially sticking out. Then the tail shaft housing goes over the part of the race that sticks out pressing it down onto the cone....There are shims that go between the race and the tail shaft housing that adjust the bearing clearance..
The failure comes when the clearance is too tight (TOO MANY SHIMS)
This loads the bearing too tight.....When the trans heats up things expand...
This causes the race in the case to lock on the cone and rotate in the case...
This wears out the case and causes the trans to get real hot real fast...Then often times the case will crack between the main shaft and the countershaft bearing bores..... Party over !!!
The bearings in the Getrag are Timken tapered roller bearings just like the front wheel bearings. On front wheel bearings you adjust the clearance with the spindle nut....On a Getrag you stack thin shims.....For new bearings you want a +.006 preload . For used bearings you want .000 clearance.....
Back in the early 90's we were having problems with the remans getrag was sending us...I had about 20 or so that we tore down to find out what had happened...I found that all of them had +.030 to +.045 shim packs.....I thought that I was not calculating it correctly or that the failed units were too bad off to be accurate...
I went to the getrag reman plant way back when to get to the bottom of what the problem was..... I pulled 3 off of the line and tore them down to check the clearance....They all had +.030 to +.045 shim packs in them as well..... Oh sh** ! I called for the production manager ....We discussed my findings...He said that they set them up this way intentionally because they felt .006 was too lose and caused excess gear rattle during testing...OMG !!!
I promptly told him that he was to stick to the spec that WE told them to use and that I was going to write my report to my superiors that Getrag was the cause of the failures and should be back charged for the failures of the remans that Chrysler had had to eat in the previous 3 years!
For those of you that have had one of the Getrags apart . You may have noticed the the rear main shaft bearing race was excessively thick....
The reason for this was that when we were testing the very first Getrags we found that under excessive load that the standard race would split and crack the case...So we reduced the size of the cone and had Timkin make a special thick walled race....It worked and hence the reason for the strange heavy race...
The best thing to do is rebuild the Getrag PROPERLY and put it back in....
There is nothing wrong with the Getrag if you know how to build them !
I have written quite a bit on this subject in the past...Look up the posts...
I know that many think that the NV4500 is a better trans....But we did have the 4500 several years BEFORE the Getrags were used...The 4500 was only used for gas trucks originally....We used the Getrag because it was found to be a better trans during testing.....The 4500 was later used behind the diesels...It had a few small changes made to it before it was used in the diesels but that was it....
The 4500 replaced the Getrag for only one reason...cost !
Rebuilding the Getrag is not hard you just have to pay attention to details...
The Getrag's problems were few but vital... The things that made them fail were as follows...
1) OIL LEAKS
A) drain plug dripped , run out or run low on oil
B) No gaskets on early models , more leaks
C) pilot bushing failures,,, bronze was too soft
D) over loading , trailer too heavy
E) too much hp , turning up the fuel/air
F) overheating ruining the oil
G) wrong type of oil , no 90 weight in the Getrag ! !
H) not knowing how to shift , rattling the gears,, too high a gear at too low a speed
2) Poor assembly
A) setting shim packs too tight , Getrag even did this themselves at times
B) uneven shim packs between main shaft and countershaft causing tail shaft housing not to hit squarely
C) bell housing misalignment
In conclusion, I personally have never had a Getrag fail in any of my personal trucks nor have I ever had to rebuild one twice that I built,, I have seen them go hundreds of thousands of miles in fleet trucks without failures.....
If you still decide to replace it with some thing else I would be glad to buy whats left of your Getrag.. I could use the spare parts ...
Good luck and be sure to replace the pilot bushing. Preferably with a ball bearing... The flywheel will need to be bored out for this...I do my own but the guys at South Bend clutch do them all the time for people.....
As for the pilot bushing....Engineering knew it was not going to work before the first one left the plant...But if you did not haul trailers it would work long enough to get out of warrantee....Engineering wanted to use a ball bearing but . We were shot down due to cost ...
In 94 it was decided to go to a Torrington needle bearing...Great in theory but it just made matters worse....They ate the imputs alive....
As for the worn out ends on the imput shafts...What I do is put them in my cylinder grinder and make them round and back on center..Then I make a steel sleeve on the lathe and press it onto the shaft end.... Then I put them in my cylinder grinder again and finish them to the correct diameter for the ball bearing I am going to use ...The tolerance is .0001 ot centerline . And no your Craftsman engine lathe you got from dad is NOT going to do the job accurately enough !
Old Sep 20, 2010 | 08:48 PM
GIT-R-DONE's Avatar
I wish I had the confidence to try and rebuild one of these.
Old Sep 21, 2010 | 12:03 AM
DodgeMonkey's Avatar
I know the man has a point about the G360 being just fine in a stock, un-modified truck, however, the NV4500 has proven to be a much stronger transmission when you start to put power to them. For $1500, you could buy an NV4500 and the Advance Adapters kit and have some money left over.
Old Sep 21, 2010 | 06:09 AM
It just goes to show they CAN take abuse if built right, Look at GHLS, KTA, STOMP, bgilbert.
All getrags and that's impressive GHLS runs 13's in a Clubcab 4x4 with a rag' and Stomp runs 13's in his utility body with his rag....that's hard on the trans and they've been doing it for years..
Old Sep 21, 2010 | 08:01 AM
lenuelmp23's Avatar
what does it cost ball park to do the nv4500 swap. i know i need to do something soon and if it cheaper or about the same as rebuilding the rag i want to swap.
