Getrag Breather/Tube?
Very worth while. I've done it two different ways on two trucks. One where I routed the breather tube up to the engine compartment with a breather cap, just like what's on the t-case and diffs, it doesn't leak. The other where I just had a section of 1/4" tubing hanging down from the getrag similar to a draft tube, such as the crankcase draft tube. It, just like many crankcase draft tubes, is a little greasy and messy. But it doesn't lose any substantial fluid. I suppose if one were to do it that way, a loop or the like would help keep it from dripping.
I have one cover that doesn't have a breather, and I have one that does. The one without the breather is in better shape, and the forks are in better shape. I would like to put a BIGGER breather on, in hopes that it works better.
