Getrag to Auto
Getrag to Auto
I've seen all of these tranny conversion threads and I was wondering if anyone on here has swapped a getrag to an NV4500. I've been pondering about this for awhile. What would it take as long as you just put a floor shifter in? Does it require changing driveline? Bolt right up? etc...
thanks
thanks
Do you want to swap in a NV4500 or an automatic??
What is wrong with your Getrag??
Can I have it??
Thanks.
Ok, my bad guys
, I was asking about switching to an auto... not sure why I put nv4500 in, I think maybe becuz i had just read a thread about the 4500... anyways, yes I'm thinking about an auto swap. And my first questions still remain
Man I feel retarded!
I see that your 2wd so no worries about the t-case. Depending on which auto you get you may need to do some wiring for the OD and or the Lock up torque converter, to go along with your floor shifter. The other thing is you may need a longer or shorter drive shaft. I think it would be easier than going from an auto to a manual.
Fergavs
May 24, 2007 02:00 PM
MJDiesel
Feb 10, 2007 10:42 AM
