Gear/Tire Ratio for MPGs
Old Jan 12, 2011 | 01:57 AM
Mike337's Avatar
I am looking to get the best fuel mileage out of my truck I can. I know I need to get the gears/tire size right for the peak engine performance. I never tow and it's a daily driver. I'm sure one of you will know how to calculate that good stuff, I have no clue. Anyone mind helping me out?
Here's what we are working with:
1989 Ramcharger with a 1990 4x4 W250 suspension.
1993 Cummins 12v non-intercooled
518 transmission 3 speed w/ OD
1990 W250 Dana 61/71 combo 3.07 gears.
16 inch rims.
Am I missing anything?
Old Jan 12, 2011 | 07:45 AM
macattack_ga's Avatar
Mike,
Sounds like a pretty cool rig!
I'm no expert, but I have discoved that these engines like to rev. Got a tach?
I think 1900-2000rpm is the sweet spot.
I had an '83 RC in college. Fun truck!
Old Jan 12, 2011 | 10:10 AM
archer2's Avatar
I have a 1991 with the 3.07's and I swapped the 727 for a 618, I still get around 17 to 18mpg which is what I got before the swap.
I agree the best mileage is in the 1900-2000 rpm range.
Old Jan 12, 2011 | 10:15 AM
You're missing tire size......very important factor.
Old Jan 12, 2011 | 11:00 AM
archer2's Avatar
Not sure if this is in reference to my post but I have 285 75 16. Same size as before the swap.
Old Jan 12, 2011 | 11:21 AM
Mike337's Avatar
Actually, tire size is what I'm trying to solve for...I just don't know enough to work the equation backwards..
When I buy new tires, what size do I want for peak performance?
Old Jan 12, 2011 | 11:23 AM
Is the ramcharger gonna be lifted?
with overdrive and 3.07's i'm not sure i"d go taller than stock but let's face it.....285/75/16 looks nice on stock diesel suspension and stock tires look small.
I think you're gonna find yourself not using Overdrive very often with the 3.07 rears So I'd just go with 285/75/16
Old Jan 12, 2011 | 12:21 PM
Mike337's Avatar
I have LT245/75/16's on it now and they look small. I wasn't going to lift it any more than the 250 suspension already did.
http://www.cumminsforum.com/gallery/.../ppuser/102573
Old Jan 12, 2011 | 12:23 PM
Yea that's cuz they are hardly 31" tall.
Old Jan 12, 2011 | 01:51 PM
Trebor's Avatar
That forum tells me [and probably a few other non-members over there]:
You do not have permission to view the images in this category.
A TALL SKINNY tire will usually get better fuel mileage than a wide lower profile version. The other variable is tread design which slightly alters the rolling resistance.
Old Jan 13, 2011 | 06:04 AM
KAyers's Avatar
From: Springtown Texas, the land of MILFs and Honeys
I hear you on liking the taller tires for aesthetics. I run the 285s on my junk too. But, a narrower tire will make a remarkable difference in fuel economy. You might look closely at the 255/85/16 size tires. They are tall but skinnier than the 285s are.
Old Jan 13, 2011 | 06:11 AM
Problem is the only tread pattern they offer in 255/85/16 is M/T and he may not want the noise of M/T's
Old Jan 13, 2011 | 06:41 AM
82shovel's Avatar
I use this calculator to figure out what happens when I change tire sizes
http://www.miata.net/garage/tirecalc.html
And I like this one to figure out what those different sizes will do to rpms at given speeds.
http://www.ringpinion.com/Calc_RPM.aspx
Old Jan 13, 2011 | 04:48 PM
GLHS's Avatar
I would run 265/75/16 or 235/85/16 for mileage (same height).
The bigger the tire, the more rotating mass too.
My "tall, skinny" tires, aren't doing so good for mileage; 255/85/16s M/T's and 62 lbs each.
Old Jan 13, 2011 | 06:55 PM
G1625S's Avatar
Yup. I went to h2's (315-70-17) from stock 2nd gen steelies (315-75-16). I could almost juggle the h2's whereas the steel rim/lot's of rubber combo was super heavy! The reduced rotating mass made a noticiable difference, imo. truck felt like I swapped in 4.10's. If I were in the original posters spot, I'd go with 235-85's or 255 85's for best mileage.
