gauge cluster
gauge cluster
The lights went out in my gauge cluster when driving home last night. Thought that my tail lights shorted out, but this morning when I left I noticed that none of my gauges were working either. Any ideas where to start looking?
As for the lights check the fuse in the main fuse block under the steering column. For the gauges, you might want to pull the gauge cluster and have a close look at the circuit board. There's a chance that some of the "paths" burned up, therefore opening certain circuits. Seems like I've always read that if even one of the gauges either reads weird or doesn't read at all, the majority will agree to check the body ground at the battery. It's just a small wire coming off of the negative terminal and grounds to the core support directly in front of the battery. Checking for good grounds is typically the first step in troubleshooting electrical issues.
Journier
Dec 3, 2004 02:33 PM
charcoal600
14
Nov 24, 2004 06:28 AM
SilverDodge
13
Feb 24, 2004 09:29 AM
cmckinney
Aug 6, 2003 12:09 AM
