Full throttle vs part throttle
I have noticed that when I floor the throttle the truck does not seem as powerful as it does at say 3/4 throttle. It only makes 30 psi of boost at 3/4 throttle and 40 psi or so at wot so I must be fueling more but it does not seem to make more power. I read somewhere on another site that backing the high idle screw out can make the pump defuel at wot does anyone know if there is any truth to that? Maybe it is all in my head lol...
Did you move the throttle linkage to the other hole in the throttle bell-crank?
If so, move it back. ;) |
The throttle linkage is in the inner hole you are saying to move it back to the stock location? That would give me less throttle travel correct?
Originally Posted by Onemoparnut
(Post 3197143)
Too much throttle travel is making him de-fuel at WOT?
I have been looking into this high idle screw, throttle / linkage adjustment as well, as a way to get extra RPMs. |
(Post 3197150)
Should I also put the high idle screw back in?
(Post 3197157)
Revisit your throttle indexing and main fuel-screw settings to ensure you're getting the most out of it. (Throttle indexing first, then main fuel-screw (adjusting based on run-away)). (I ran into this same issue). |
My throttle indexing has never changed what do you mean revisit the indexing?
Originally Posted by BC847
(Post 3197161)
(Post 3197162)
texttomakethepost |
I thought that the indexing always stays the same? How do I index it to make sure I am getting the most out of it? I thought when they were off a notch they are hard to keep running. Sorry if I seem dumb here but I am kinda lost thanks for the help though.
There isn't a whole lot of difference in my truck between 2/3 and full throttle. I just figured the POD's were maxed out.
(Post 3197172)
Either way, one can move the throttle indexing one tick this way, or that, and reset the main fuel-screw like you would otherwise (looking for just before runaway). - To one extreme, you may be able to run the fuel-screw all the way in, with NO runaway. - And the other extreme, run the fuel-screw in a lot less than before, and get runaway. The latter of the two will get you more usable throttle range with maximum fueling. |
David. Iirc you switched to the 3800 spring. Did you clip that to match the length of the stock spring like you did with the 3200 when you were running that?
Sent from my Galaxy SIII via tapatalk 2 |
When I put my 3200 spring in I did not clip it or change the throttle indexing. should I remove the spring an clip it? The throttle indexing is in the exact same spot it was when it was stock.
| All times are GMT -5. The time now is 03:22 AM. |
