fuel pin installation
From: great state of illinois but moving to michigan in a few months
wats up guys, i just bought a dennyt stage two fuel pin. before i install it i wanted to make sure of a few things. when you put the new fuel pin in do you need to replace the nylon washer if so where can i get one and wat size should it be? also wat type of grease should be used on the fuel pin and do you just coat a little bit on the fuel pin itself or do other things need to be greased? and last does it matter whigh way the fuel pin is facing? any help would be greatly appreciated thanks ahead of time
Just put some "if you have synthetic" on the cut part of the pin. You shouldn't need a new nylon washer. And turn the pin to where the cut is to the front of the vehicle "front of the pump inline if you will with the shaft of the pump". I put a very very light coat of grease almost invisible on the lower section of the pin but it's not necessary. Hope this helps. Good luck you will like the pin.
ps-Fill out your sig so we can see what truck ect you have, it will help the guys on here help you if you need help on stuff.
just got it all installed. now i gota go try it out. i ended up reusing the old nylon washer but i was confused on if you guys were saying that i could reuse it or if i didnt need to put in a washer there if someone could clear that up for me i would appreiciate it thanks again for all the info
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
