Fuel Pin
Old Aug 18, 2005 | 03:23 PM
FIREDUDE's Avatar
Fuel Pin
Ok, im been reading threw past forms and have got confused which one is the fuel pin, the one that pokes out when u open up the throttle or the one that is on the end of the afc thing on top of the pump and how u do go about grindin it
Old Aug 18, 2005 | 05:26 PM
hertz's Avatar
It's under the four screws on top of the pump. If you take it off mark eerything and remember where everything went. Its the eccentric thing, cone shaped.
Old Aug 18, 2005 | 06:20 PM
FIREDUDE's Avatar
well does anyone know how u grind it down
Old Aug 18, 2005 | 07:42 PM
hertz's Avatar
I would lay down $200 for a old smokey one comes with a spring, thinner washer, and new pin. All the guess work is done for you it takes about 10 min. to install. Do a search under 1st gen and you'll get the website it's worth the money.
Old Aug 18, 2005 | 10:19 PM
FIREDUDE's Avatar
but how do u grind the STOCK fuel pin
Old Aug 19, 2005 | 07:00 AM
fearthedeere's Avatar
with a lil air dye grinder, find the offset side and have at it.
Old Aug 19, 2005 | 07:48 AM
Boatnik's Avatar
Hey Firedude if you mess up I got a stock one in my tool box I will give you. BullyDog makes a fuel pin too. It is real easy to change if you listen to some of these guys. There is a lot writen on the subject here in DTR. Send me a PM if you need it.
Old Aug 19, 2005 | 08:52 AM
hertz's Avatar
Dynomite diesel carries the Old Smokey Fuel Pins.
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
West Coast
May 26, 2007 10:22 PM
bigragu
Oct 17, 2005 04:07 PM
Crimedog
Mar 11, 2004 01:54 PM
