Fuel Heater leaking from the plug
Old Sep 7, 2009 | 07:17 PM
Buddy Stewert's Avatar
I have fuel leaking from the plug on my fuel heater. All this started after i power washed the engine. Any ideas I checked the fuel filter for any thing obvious nothing..
Old Sep 8, 2009 | 09:26 AM
Boatnik's Avatar
Do you mean the vent or the electrical connection?
Old Sep 8, 2009 | 10:52 AM
Fuel heater
It leaks more when i pull the electrical plug from the heater what tool do i need to remove the fitting that holds the filter and heater in. Need to get a better look at it. I could have damaged the O ring when i power washed the engine. Thanks
Old Sep 8, 2009 | 03:27 PM
It's possible that the leak is from the plug. I've had numerous sensors/switches do that.
There's no way washing the engine damaged the o-ring.
Other than a 9/16" drag link socket, the best tool I have seen is a ground down cold chisel.
Old Sep 8, 2009 | 08:11 PM
I removed the Fuel heater did not see any cracks looked the O ring over cleaned everything and put it back together pumped up the fuel pump and i can hear the fuel / air leaking. I need to get a mirror to see up from the top or have a friend pump the pump and look up from the bottom of the truck. Tomorrow.Thanks
Old Sep 9, 2009 | 03:58 PM
Rust
I found the problem removed the Fuel heater and got a better look at the area that the heater bolts to and found a bunch of rust build up around the sealing area. Cleaned the rust of and put a new O ring in from the Hardware store. I will get the stock one next time i get to the dealer.
NO LEAK. THANKS WITH THE HELP
royta
Nov 25, 2016 11:48 AM
jesussaves
Oct 23, 2009 06:52 PM
modiesel
Mar 7, 2008 10:44 AM
ctturbodiesel
Dec 13, 2006 09:37 AM
