fuel filter
fuel filter
new to me 92 dodge and doing the fuel filter.When i took it out the fuel heater(?) came with and i was careful to not push it into the block.put the gasket back on it and got the whole threaded part back on to the block,now i have a leak between the heater and block it apears.I am almost positive i have the orientation right on it,plastic side up,metal side towards the filter.is there a gasket that goes between the threaded part and the heater?
Yes there is. My 1990 had the same issue. You can get a new gasket from dodge or cummins. Ifyou are in a bind, pull the old gasket and find a gasket off of a oil filter. The rubber gasket off of the oil filter will be thicker,but i did this about 4 months ago,and still have no leaks. The correct gasket is still in the garage.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
