FSM Wiring Diagram Needed 1990 W250
I'm in need of a wiring diagram if all possible for my '90 W250 non-intercooled CTD with a 727/NP205. I bought this truck and the wiring harness that runs to the VSS and neutral safety switch on the trans is completely missing. There is a 10 pin weatherpack connector on the main wiring harness under the hood that harness that I'm missing should plug into. PO has jumped a couple wires to by pass the neutral switch and the speedo is in-op of course. I've searched all around but apparently this is a '90 ONLY wiring because 89 had the speedo CABLE and 91 has OD trans with the module.[dummy] I'm more than willing to just build my own harness to get all the stuff working but have no idea what each pin in the connector goes to or controls[yuk]
$35 plus shipping
http://www.genosgarage.com/1990-DODG...nfo/DFSM90_CD/ or if you want the hard copy it will cost you $120 |
3 Attachment(s)
Originally Posted by JimmyM
(Post 3233334)
That being said, here is some of the info I found for you. Attachment 42874 Attachment 42875 Attachment 42876 |
I just ordered the FSM from Genos for my 92. I've been using the 93 FSM for a while now, but I think there are some things different in the 92's that I may need sometime.
With shipping it cost me about $44, but well worth the money spent. EBAY has used FSM in paperback form for under $30, but not sure what you would be getting in a used mechanics book without actually seeing prior to purchase. |
