Front springs ,,,rubber pads????
Lost rt., front ball joint, tore-up upper"A" frame, found doner trk. the front springs have rubber pads top& bottom( my 91.5 d250 don't) want to use doner springs as well as "A" frames, also doner springs are not tapered on the top ends, doner is a 92 d250 2wd ,whats w/ the rubber pads??? The spring not being not tapered, will they still work ok,???
whosdunit.
whosdunit.
Looks like i'll reply myself; went back to one of the doner trks.,d350 93 mod., the rubbers are on top& bottom of the coil springs,, maybe to keep the springs from squeaking or poping,,,,,,,,,anyone,,,,,??
Hey user, i have one side in, w/ the rubber on them the other side tomorrow, would of had both sides...but lower"A" had worn bushings on left, the springs are out of a 93 d350 ,will let you know if all works out.
Chip
14
Jun 21, 2009 03:59 AM
rjm022
Jan 4, 2008 10:16 PM
ImpulseHydro
Oct 5, 2007 07:04 PM
