Front Leaf Spring Shackles for a 92 W250
Old Oct 27, 2019 | 09:22 AM
Bullelkklr's Avatar
Originally Posted by MARF75
Get some same thickness plate and make them.very easy and you can extend them a tad for more lift if you so desire
If you do this should you also extend the front shackle bracket to keep the caster equal?
Old Nov 13, 2019 | 06:03 PM
E.Roy's Avatar
Here's a high quality option to replace the front shackle mounts THAT DOESN'T require taking a hole saw to your frame, as the DOM tube is sized to fit in the factory hole with a slight clean up, plus made out of 3/8" plate.
https://archivegarage.com/explore-ar...-frame-shackle
Old Nov 13, 2019 | 06:29 PM
I have used some of the Archive Garage parts on my '91.0.
The front of the rear spring hanger mounts where top notch and they bolted up as described.
I will use his parts again on another build.
Old Nov 13, 2019 | 06:41 PM
https://www.youtube.com/watch?v=O8HyaTzHpGs
Sweet
Brian.B
Aug 30, 2023 01:23 PM
Mopar1973
Sep 25, 2011 05:27 AM
Ruckus
Aug 14, 2011 03:49 PM
eng208
Dec 1, 2004 09:37 PM
spitzair
Jul 8, 2004 11:39 PM
