front cover timing seal
i was seeing if i put seal on dry or do i add some red silicon to it .
That would be ok just go easy with it.
Keep it off the lip of seal. I know you now that. |
Originally Posted by td3620
(Post 3069586)
No silicone on the outer, metal surface of the seal. Red Loctite is the recommendation. The seal goes on the crankshaft dry when you install the front cover with the seal in place. Be sure to place the plastic sleeve (came with the seal) over the snout of the crankshaft prior to installation. That prevents the lip of the seal from folding forward.
