Fluid dampr?
Anyone running one of these on a 1st gen, worth the $$$?
Do a search....there was a thread on it a few weeks ago but cant remember what it said.
I put one on my 96 and realy like it it is smoothe and has make things a little quieter.
befor http://www.youtube.com/watch?v=G_ABeAc4yDs after http://www.youtube.com/watch?v=3JN5F...eature=related It may be hard to tell the diff on the vid but its night and day when you drive it. Pluss my stock one was about to fly apart. |
It definitely sounds smoother with it on
it realy helps at over 2500rpm.
It wuzzzz meeeee!!!!
Originally Posted by rbrettctd
(Post 1868334)
Yup! It was me, I saw it in Diesel World probably the same place HAMMER_DOWN saw it. Here is the link: https://www.dieseltruckresource.com/...monic+balancer Hope that helps! |
The only fluid dampr i have seen for 12v is for 91.5+ but what about us that have an earlier version?
Originally Posted by dieselcarpenter
(Post 1868624)
Originally Posted by 1stGen545
(Post 1868590)
I run a Fluidampnr and find it worthwhile albeit expensive. Definitely smooths things at idle as well as wound up.
The Fluidampnr type is a stock/OEM item on certain industrial applications as well as the marine engine. :) |
Are ALL marine applications using the fluid damper???
Just curious, what does a stock Cummins dampner cost versus a Fluiddampner? I think I'm going to get one after I purchase my DDP Stage IVs
The rubber ring was about to fall out of the front and had large chunks missing on the rear. The alignment marks on the 2 halves had slipped just a little.
I want one! They are standard issue on racing vehicles.
here is why I pulled the stock one. You tell me how you would feel with this doing 4000 rpm
