first gen fuel problem???
Old Apr 4, 2009 | 12:15 PM
firstgen250's Avatar
hey guys, help if ucan....i havea 91250, fivespeed, fully cranked fuelscrew,p.o.d. injectors, home built air filter.....just replaced fuel pump,(stock) and replaced all fuellines with 3/8 rubber....hauling a bobcat the other day under a load the boost gauge fludders and u can hear it through the air cleaner.....????please help...i do have plans of puting a piston fuel pump on...Is this a fuel problem, should i be worried about this....
Old Apr 4, 2009 | 12:53 PM
It's the turbo compressor surging. A compressor upgrade kit will fix it.
Old Apr 4, 2009 | 01:16 PM
what do you recomend
Old Apr 4, 2009 | 02:39 PM
A compressor upgrade kit will stop the surging. HTT and GDS both sell them.
If you can afford it, a bigger turbo would be a better choice. POD's and a turned up pump are a little more fuel than a hybrid can keep cool.
Old Apr 4, 2009 | 03:03 PM
thank you very much, i figured it was a fuel problem, but i also thought of the turbo...i will most likly go with the upgrade...would it be smart to rebuild the turbo when its apart??
Old Apr 4, 2009 | 05:02 PM
The turbo doesn't even have to come off the truck, you just pull the intake hose and drop the downpipe. As long as there is no discernable endplay in the shaft and you can't make the wheel hit the housing there's no need for a rebuild.
Old Apr 4, 2009 | 10:20 PM
Thunderhog's Avatar
I used the GDS, about 1/2 the price of the HTT. VERY easy to do, just make sure you have an INCH pounds torque wrench ava. It is a great next step before a new bigger Turbo.
Old Apr 4, 2009 | 10:22 PM
Thunderhog's Avatar
OH YEAH! you go up to a 4" inlet as well. Either get a 2nd gen hose, or a custom intake. Lots of different ways to go there.
Old Apr 6, 2009 | 03:45 PM
thank you guys for all the ideas i have started to check in to the upgrade....cant wait, also i still have to do the gov spring, i have it just cant get the truck shut off long enough to do it.....
Old Apr 6, 2009 | 06:13 PM
rollincoal23's Avatar
you will love the addition of both upgrades.
mknittle
Mar 3, 2014 09:04 AM
209trucker
Sep 28, 2013 07:06 PM
penguinman
May 7, 2012 05:02 AM
rascal
Aug 23, 2011 07:22 PM
MikeThomas
Feb 12, 2007 05:51 PM
