first gen Cummins side marker light
Is the any different side marker light that I can install in place of the factory one that doesn't require cutting the fender. The one got busted off and is no longer usable. I would like an LED light to replace it with. Thanks for any ideas.
A LED will cause you problems. The side marker is part of the ground for the turn signal system also. The LED light will back feed into the turn signals when you turn the markers on.
Jim L has a write up on the stickeys how to use them. He also gives numbers for a LED marker. Its a pete front fender marker light.
Here is a video of my front markers. These are from superbrightled.com.
I wired my front markers and those side lights a little different than Jim did.
My front turn and marker lights are LED from the same place. I just modded the orginal turn signal housing to fit the 3x6 oval light into it. If you want pic's of that I got some.
AggiePhil
10-27-2005 11:35 PM
03CTDCO
02-22-2005 10:22 PM
