Finally drove truck empty 19.24mpg
Old May 23, 2005 | 11:48 PM
DJ's Avatar
DJ
I finally got my suspension softened up enough to try a road trip empty. First highway driving empty since I got the truck (20,000 miles ago) Drove about 240 miles about 80 percent highway 60-70 mph as traffic would allow, ac on and got 19.24mpg. I thought it was pretty good but have to confess I had hoped to break 20. Guess than means I've got things set pretty well. Finally finished painting it too. Stock kinda greenis/bluish metallic color. Emerald green I think they call it. Paint was starting to peel all over and hood and roof were starting to get small rusts pits. Took a long time to strip it to metal, treat the metal, epoxy prime, fill prime and them paint. Still have to finish polish it but its looking pretty good. I'll have to wash it and get a pic up. Now if I can find a new drivers seat frame I can re install the seat and everything will match. By the way my tach shows 2050 rpm at 70 with 3.54 gears and 265 75 r 16 tires. Is that about right or does my tach need a little tweaking.
Old May 24, 2005 | 02:04 AM
Dan Brooks's Avatar
I wouldn't be disappointed with 19+ for a 4WD. I haven't taken mine on an empty freeway trip in quite a while, but I only got around 22 MPG *at best* with my 2WD. I normally average 17-18 MPG around town, which is where mine is driven most of the time.
Old May 24, 2005 | 05:58 AM
jleonard's Avatar
That sounds about right to me. I have the same size tires and ratio.
Old May 24, 2005 | 08:51 AM
92DIESEL's Avatar
I just finished my third fill up after tweaking the pump, 16cm housing, 3200 spring, and grinding the foot (thanks Dave and Dave) and I average 20.37mpg I was hoping for a little more but I can't complain. This is driving 85% hiway at near ludicrus speed for most of it. The next fill up I get I'm going to try doing the "limit" posted wish me luck
Michael
Old May 24, 2005 | 09:10 AM
jleonard's Avatar
Doing the limit will make a good difference...but it's no fun.
Mileage goes up and smileage goes down!!!
I can get 24 daily and 26 on a trip if I drive sanely.
Daily I get 21/23 but I'm at 70/75 a lot. (ok 80)
Oh well.
Jay
Old May 24, 2005 | 10:18 AM
efbeason's Avatar
Will performance injectors get better fuel mileage than stock ones?
Old May 24, 2005 | 10:55 AM
jleonard's Avatar
They will get the same or better...
Mileage is MORE dependant on the angle of your right foot!!!
Old May 24, 2005 | 03:56 PM
Michael - Wow! 20.3 mpg? Is that worse than before?
DJ- I think you're doing well. My truck, even stock, never did better than mid 18's on the highway at 70.
Jay's comments about injectors do not apply to POD's - at least in town. I lost 2 mpg in town when I put in the POD's, highway is the same as always.
Old May 25, 2005 | 12:18 AM
Hemi Cat's Avatar
Your mileage sounds good to me too. I get 18 driving 70-75 mph and if I can slow down for most of a tank to 65 I can get 20 mpg. When fuel hit $2.50 / gal, I had more incentive to slow down.
Old May 25, 2005 | 08:00 AM
92DIESEL's Avatar
Dave- this is a drop of about 1/2mpg- but the power is
now I just have to make a custom intake- the stock one keeps coming off
Michael
Old May 25, 2005 | 09:30 AM
jiMMyCTD's Avatar
you will like a custom intake!
Old May 25, 2005 | 10:31 AM
92DIESEL's Avatar
jimmy, where did you get your elbows, I cant find them except online?
The stock one fell off again today and now there is play in the turbo so I need to do something.
Thanks,
Michael
Old May 25, 2005 | 07:15 PM
redhornet's Avatar
Intake fell off again?? ........what part falls off of what,sounds like something I should be checking on my '92.thanx
Old May 25, 2005 | 07:18 PM
The stock intake hose doesn't like to stay connected to a BHAF. If you bark the turbo the hose blows off. Sometimes it just falls off for no reason. That's why I put together the setup that's on my truck.
user name
Feb 10, 2012 03:57 PM
HOHN
May 6, 2008 03:30 PM
bobbyr35
May 5, 2008 08:04 AM
Just4Smoke
18
Nov 11, 2006 05:44 PM
Rattletrap1
Dec 21, 2004 01:29 PM
