feul problem
Old Jan 2, 2015 | 01:32 PM
td3620's Avatar
Question feul problem
I rebuilt whole motor.it wont start. We aint getting fuel to fuel pump. Had to replace o ring rubber seal on fuel line. still nothing. You think my lift pump out.its new it sat on self for year while I was rebuilding it.?
Old Jan 2, 2015 | 02:07 PM
j_martin's Avatar
Did you clean the mud dauber's nest out of the fuel line before you hooked it back up?
Old Jan 2, 2015 | 07:40 PM
td3620's Avatar
yes sir,
Old Jan 2, 2015 | 07:56 PM
j_martin's Avatar
Originally Posted by td3620
yes sir,
Using a rag, low pressure, and good judgement, put a little air pressure on the fuel tank at the filler for about a minute.
1. Leaks somewhere, you found the problem.
2. No leaks.... disconnect the line at the lift pump inlet and stick it into a bottle. Air the tank again. Does fuel flow?
a. Yes..... lift pump bad.
b. No, fuel line plugged.
I'm assuming you have battery at the FSS, and that the FSS is good.
Old Jan 2, 2015 | 07:59 PM
td3620's Avatar
did that fuel line flows good. bad pump I wreckin
Old Jan 2, 2015 | 08:04 PM
td3620's Avatar
would then pump still pump okay even if its out too
Old Jan 2, 2015 | 09:38 PM
j_martin's Avatar
Theoretically, the vane pump in the IP would pump enough fuel to run, however, when a lift pump is bad, the check valves in it are still restricting the fuel flow, and if there's the smallest leak, it'll allow enough air in to kill prime.
There's a lever on the lift pump, used for bleeding. If you bleed the system, then crank the engine while operating that lever, it should start. If it doesn't, then something else is wrong, IP or timing.
Old Jan 2, 2015 | 09:49 PM
patdaly's Avatar
Do you feel any resistance while pushing the priming lever?
For giggles did you turn the engine over at all since using the priming lever? ( Could it still be on the pump lobe of the cam? )
Old Jan 5, 2015 | 10:55 PM
td3620's Avatar
Question still no fire
I replaced lift pump/ fuel pump. Finally got fuel through, but it still wont start up and run. Yall think it might be pump out of timing? Any ideas thank yall
Old Jan 5, 2015 | 11:05 PM
td3620's Avatar
im getting fuel to injectors and furl pump too
Old Jan 6, 2015 | 08:22 AM
patdaly's Avatar
Double check your timing then.
Old Jan 6, 2015 | 11:55 PM
How much of an injection pulse are you seeing? With the injector lines loose it should be spraying all over the underside of the truck. If it's not then there might be internal IP issues.
Old Jan 8, 2015 | 08:56 PM
td3620's Avatar
starting problem
fuel spraying normal out of injectors
Old Jan 9, 2015 | 01:10 AM
If you've got a good strong injection pulse, then it's either timing, or perhaps the motor is not spinning fast enough?
Double check that the woodruff key did not come out when installing the IP.
Old Jan 10, 2015 | 02:28 PM
ezazel01's Avatar
are you feathering the throttle while starting? turn up the fuel screw possibly if you've messed with it before the rebuild... OR, like thrashing cows said about the woodruff key. pull the oil filler tube mark the shaft bolt and gear and start turning to see if shaft is slipping. If its not slipping then turn up the screw or adjust idle and or your throttle position is off. Hope this helps. I just went through my pump and had a few hiccups.
whttacoma
Dec 1, 2007 02:23 PM
rnoland1970
May 7, 2006 12:45 AM
WildBrando
May 1, 2006 08:54 PM
CLHaney34
Mar 18, 2006 07:56 PM
O.fO.shO
Dec 14, 2005 08:32 PM
