F-350 cc front hub onto my d60?
Old Mar 28, 2009 | 11:53 AM
u.s mma's Avatar
My buddy called me last night, said he is going a different route with his high pinion 60 out of an 88 f350 cc. Said I can have his front hub to finish my dually conversion. Any one know if it would work or not? I don't have time to pull everything apart to find out it wont' work.
Old Mar 28, 2009 | 03:07 PM
smoking's Avatar
http://www.pirate4x4.com/tech/billav...ont/index.html
This is the most useful link I have ever seen for the dana 60's. 2 pages of data that should answer your question.
Good luck, Danny
Old Mar 28, 2009 | 03:27 PM
jlast's Avatar
NO ford is different then C/D
need internal or external lock hubs, i can help
Old Mar 28, 2009 | 03:34 PM
DarrinGT's Avatar
If you are doing a Dually Conversion have you checked out http://www.arrowcraft.com/ ? They have bolt on adapters and complete dually conversions.
I did a complete conversion on a 92 F350 and it is quality stuff!
Old Mar 28, 2009 | 04:37 PM
Alwaysworking's Avatar
alwaysonDTR
i think you can change everything, except the housing over, just swapt the knuckle out, some fords have a 5 bolt spindle mount vs a 6 but if you change the knuckle that doesn't matter.
from what i've found this should work
82F100SWB's Avatar
You can machine your spindles to run the Ford hubs, or swap everything from the knuckles out, but, it's not a direct bolt on either way. The steering arms are located differently on the knuckles.
Check with these guys http://extremeaxlesales.com/wheelhubs.aspx
Those Chevy internal hubs will go right on your axle.
BC847
Feb 26, 2019 07:13 PM
Rafter B
Jan 11, 2009 08:40 PM
Bobcat698
Sep 26, 2005 12:19 PM
Dieselhead
May 7, 2005 01:36 AM
Swamp_Donkey
Feb 21, 2005 05:18 PM
