Evacuating the crankcase
Old Aug 12, 2021 | 06:05 PM
mhuppertz's Avatar
Going to weld this into my downpipe (idea from my Hemi days) and connect it to the two ports I have in the billet tappet cover and put a restricted breather on the fill pipe that I had previously converted to a third breather. I have a fill point on the first valve cover I "borrowed" from my 4BT.
I'm hoping that this will cure my external oiling issues that I have even with a decent size oil separator. If I modulate the vacuum pressure I might get the benefit of reducing ring flutter which will further reduce blow-by at high boost.
Old Aug 13, 2021 | 10:43 AM
cougar's Avatar
Good idea, but may not work. Unless the design of those valves have changed they were exhaust pulse driven like a pump. Post turbo, those pulses may have been broken up and will no longer drive the valve. Also, there is a lot of oil floating around the tappet cover. If you already have a lot of blow by, you could wind up with a bigger mess.
Old Aug 13, 2021 | 11:53 AM
mhuppertz's Avatar
It's actually a completely passive device, one way check valve, that's it. Vacuum is created by the venturi effect of the pipe in the airstream, and it evacuates the crankcase. You have to be careful not to restrict the incoming air too much because it will suck the pan gasket in.
Old Aug 13, 2021 | 01:51 PM
mhuppertz's Avatar
And if that doesn't work (and I know it will) I always have this
mustangmarty
Sep 5, 2018 04:08 PM
BC847
Jun 19, 2018 06:32 PM
1985cucv
May 25, 2009 08:57 AM
05ChainSmoker
Jul 20, 2008 10:20 PM
mcevins
May 18, 2004 07:24 PM
