Engine weight
Old Apr 25, 2010 | 09:35 PM
Montana2x2's Avatar
Engine weight
How much does an accessorised 6BT weigh? Can you pull one with a cheap chinese 2 ton cherry picker? Thanks.
Old Apr 25, 2010 | 09:45 PM
JQmile's Avatar
1000-1100 give or take, I think.
Old Apr 25, 2010 | 09:50 PM
93flatbed's Avatar
Mine came out with one of those pickers. It wasn't happy about it but It did do the job.
Old Apr 25, 2010 | 10:04 PM
TIMMY22's Avatar
I pulled the motor and tranny together. It was 1400 pounds as a pair.
Old Apr 26, 2010 | 10:07 PM
Montana2x2's Avatar
No wonder the front springs take a beating. Thanks
Old Apr 26, 2010 | 11:33 PM
schamran's Avatar
I would just be real careful. My cousin put extensions on the legs of his so that they were farther under the truck. The dumb thing just tipped forward when we tried to jack it up. (motor only)
Old Apr 26, 2010 | 11:52 PM
jimbo486's Avatar
my cummins shop manual says a dry weight of 880lbs "minus the flywheel and electrics." the flywheel is around 55lbs and i don't know just what they mean by "electrics."
Old Apr 27, 2010 | 09:56 AM
Trebor's Avatar
I believe that 880 may not include the oil, oil filter, fuel filter, starter, alternator, alternator brackets & mounting (no upper water outlet), no fan and possibly no fan mounting or power steering, vacuum pump or air compressor. In other words the basic engine no lube or residual coolant and before it becomes accessorized for specific use in a Dodge pick up, or a Ford medium duty chassis or even an air compressor.
Old Apr 27, 2010 | 09:07 PM
Alwaysworking's Avatar
alwaysonDTR
1225 lbs with the 727 2wd auto.
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
Flashpoint
Feb 28, 2006 11:26 PM
MoparMarv
Jan 17, 2006 12:49 PM
Mark Hodowanec
May 8, 2005 08:02 PM
